Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 04-26-2020, 03:52 PM
dg27's Avatar
dg27 dg27 is offline
Default Re: XLR versus TS
Thanks--that's what I was looking for: whether it was electrically the same.
I opted for XLR to XLR for the reason you stated. These will be connected at all times and the TRS worried me because they're in the front (in the rear didn't matter much).
Thanks again.
Be Quiet Pure Base 600 case * Core i5-12600K * Gigabyte Z690 UD AX * 32 GB G.Skill Ripjaws DDR4 * 2X HP DreamColor Z24x G2 displays * NVIDIA GeForce GTX 960 * Samsung 980 boot drive * Samsung 870 EVO PT projects drive * Samsung 860 EVO PT archive drive * Novation Impulse 49 MIDI * PreSonus Studio 26c interface * PreSonus Bluetube V2 preamp * PreSonus HP4 headphone amp * JBL LR 305 monitors * Sennheiser HD 650 headphones *
Windows 10 Pro 64 21H2, Pro Tools 2022.7.0
Old 04-26-2020, 03:53 PM
JFreak's Avatar
JFreak JFreak is online now
No problem
Janne
Old 04-26-2020, 04:11 PM
Top Jimmy's Avatar
The 26c line inputs are accessed via the TRS part of the combo jack. The XLR part is mic level only. Therefore, the appropriate cable from the preamp to the interface should be XLR-TRS.
James Cadwallader
Old 04-26-2020, 04:16 PM
JFreak's Avatar
Are you sure?
Those look like Neutrik combo connectors which mean they only have 3 pins out of the connector, not 6 -- so whatever you plug in is electrically just the same. Software changes between mic/line/inst levels
Janne
Old 04-26-2020, 04:36 PM
Ben Jenssen's Avatar
Off topic:
One pluss for TRS over XLR: on a TRS patchbay output you can insert the jack half way and not break the flow thru the patchbay, like a "tap".
Added: TRS inserts on audio interfaces and mixing desks also work this way. It provides a kinda "secondary output" for the channel that can be very useful, and I think many aren't aware of it.
  #16
Old 04-26-2020, 05:05 PM
dg27's Avatar
Thanks for the clarification. I changed my order to TRS, which is what I've been using in this context for years.
  #17
Old 04-26-2020, 05:40 PM
Top Jimmy's Avatar
Originally Posted by JFreak View Post
Are you sure?
Yeah. The Neutrik combo jacks have 5 pins. The signal contacts are separate and the ground is common. At the very least, manufacturers will put blocking caps on the TRS portion to block phantom. In this instance, Presonus also added a switchable
pad on the TRS part to bring the input gain into the line level range.
James Cadwallader
  #18
Old 04-26-2020, 08:01 PM
dg27's Avatar
Thanks for the useful education!
  #19
Old 04-27-2020, 03:33 AM
JFreak's Avatar
Yea, always good to learn something
Janne
  #20
Old 04-28-2020, 05:23 AM
dg27's Avatar
I had sent a query to PreSonus tech support at the same time I posted here, but knew I wouldn't hear from them right away.
I asked:
When connecting the Studio26c Mic/Inst/Line to the BlueTube (preamp), does it make any difference whether the connection to the 26c is TRS or XLR? I've always used an Unbalanced 1/4" TRS Male to 3-Pin XLR Female Audio Cable. Would it be better to use an XLR M to XLR F Microphone Cable?
They replied:
Yes it does, TRS is for Line Level and XLR is Mic level. You would need to use TRS for this connection.
7.3 versus 7.1 on G4? Moz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-02-2008 08:45 AM
Mac G4 versus G5 versus Windows XP progress88 General Discussion 22 09-08-2003 08:45 AM
M-149 versus? DougP General Discussion 15 10-03-2000 05:38 PM
OS 9.0.4 versus 8.6 dodged forgottenn Pro Tools TDM Systems (Mac) 1 09-02-2000 06:21 AM
