  #21
Old 09-25-2015, 08:53 AM
Oliver M Oliver M is offline
Default Re: Automation AppleScripts for Pro Tools (Mac)
Originally Posted by Linck View Post
Ok. Im trying to figure out how you manage to use/automate the chekbox in the save session as, with audiofiles? I would like to do some script for bouncing different types of files and video..
I use the application UI Browser to check and access the Pro Tools User Interface elements.
Remember that Pro Tools is not Apple scriptable, thus you gotta work with GUI scripting.
See MacOSXAutomation.com for more info.
Again, thanks allot for the scripts:)
You're welcome. ;-)
  #22
Old 10-07-2015, 02:48 PM
There have been changes made in PT 12.2 regarding AppleScript. Some of my scripts broke due to this.
I have updated all of the scripts but before I release them to the masses I'd like some testers to help and try them out first.
Please, send me a private message if you are interested to help.
  #23
Old 10-18-2015, 07:00 AM
Update 1 of Vol. 1 is available now.
Important:
Make sure to delete the old scripts first before running the installer, else you will end up with a mess.
Pro Tools Automation Scripts Vol. 1 - Update 1
What’s new in Update 1 (10/2015)
  • All scripts and the installer are code signed now, thus Gatekeeper savvy
  • Support for Pro Tools 12.2 and higher has been added
  • Some scripts have been slightly renamed for different reasons
  • The Save Session Copy scripts have been enhanced by a 4th script which saves the session copy with audio files only
  • All scripts should work with OS X El Capitan, however this has not been fully tested as there has been no El Capitan compatible Pro Tools version released yet
Minimum System Requirements
  • OS X 10.8.4 or higher, Pro Tools 11.1 or higher
  • Pro Tools and OS X running in english
Download Pro Tools Automation Scripts Vol. 1 - Update 1
  #24
Old 11-11-2015, 07:31 PM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
Important:
I WAS LOOKING FOR THIS KIND OF SCRIPTS!! THANK YOU YEAAAAAAHhh
sorry for the caps but it's 3:30 am here
Can I ask you just some little things? If yes, here is the first one.
What it's the command to select inside a menu, example:
I open Selected Tracks as New Session... and I want to make a tick on the items to copy - > audio files
I already made a script that call's the "Selected Tracks as New Session..." menu :) that's why I'm still awake at 3:30am
Thank you so much for this.
Regards,
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
  #25
Old 11-12-2015, 01:35 AM
Hi Marco,
thats:
Code:
click checkbox "Audio Files"
Wrapped in a tell block:
Code:
tell application "System Events"
	tell process "Pro Tools"
		tell window "Save Session Copy"
		end tell
	end tell
end tell
Oliver
  #26
Old 11-12-2015, 08:27 AM
Hi Marco,
thats:
Code:
Code:
		end tell
	end tell
end tell
Oliver
Nice lets see if I can do it :)
Thank you so much
Marco Bernardo
  #27
Old 01-04-2016, 06:38 PM
I am wondering if anyone has noticed any issues with the scripts under El Capitan. As an example, do you notice any slowness when running the Save Session Copy script?
  #28
Old 01-04-2016, 07:03 PM
Im still not in El Capitan, but I have some time tomorrow and I could install in one machine and test it. I give you some feedback tomorrow.
Marco Bernardo
  #29
Old 01-06-2016, 04:26 PM
OK, seems like it didn't work out Marco.
Anyone else?
  #30
Old 01-06-2016, 04:28 PM
Anyone else?
I did install El Capitain, but didn't have time to test it, I was asked to do some mixes. Let me see if I can test it with Team viewer connect to the DAW at work.
Marco Bernardo
Pro Tools 12 Trim Automation [email protected] Pro Tools 12 2 08-16-2015 04:25 AM
Pro Tools 11.2.1 Automation Bug?! Gneal550 Pro Tools 11 1 11-22-2014 01:15 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 08:21 AM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
AppleScripts and other Macros for PT Bergeron Tips & Tricks 1 11-15-1999 06:55 PM
