Mastering Tips
I wanted to know if someone could help me to understand how to master effectively in protools, I want to get a more transparent session going? I produce HipHop /Trap music and work a lot with 808 bass beats and synths with snares. My stems come from presonus studio one and when using this system i lose transparency in the song after bouncing to disk the sound quality is changed to a lower volume in my basses and snares drums. All of the other instruments still sit in the mix correctly though(synths, rifts)!I am importing song tracks into pro-tools to master but am not sure as to which effects plugins to use. The stems that I am importing are wav files from my presonus sessions. I can master them in presonus but i want to try to master in Pro-tools because it is my favorite tool from most things. If someone has some ideas that can guide me in the right direction concerning then it would be appreciated. Thanks, panther1
Re: Mastering Tips
Plenty of tutorials on youtube
Re: Mastering Tips
Hey there,
A little advice to keep you from grief down the road when you start interacting with pro's: It's a real good idea to get basic terminology correct. Do you mean "tracks" or "stems"? Individual instruments like vocals, beats, synths, bagpipes, etc. are generally referred to as "tracks". Submixed groups of tracks, 808, bagpipes, synth pad, drums, etc., are referred to as a "stem". Usually stereo, but often mono. (Typically.......it can also get really complex) Why bring this up? Most of the time, we are sent stereo files to master. The rest of the time, we are sent stems.....guitars mixed in stereo, background vocals mixed in stereo, groups of drums, etc. That way, we end up with 2 to ten stereo tracks of the song. That allows us to bring certain groups of vocs/instruments up or back or apply processing individually as things change during mastering. The mastering guy becomes a final tweak mix engineer. Stems. Good luck.
bookerv12 |
Re: Mastering Tips
I suspect the op is really asking about mixing and NOT mastering. |
Re: Mastering Tips
If you haven't got the 'transparency' (by that I take it you mean spatially multi dimensional) happening in the mix, no amount of mastering is going to get it. This is a very good video IMHO. It concentrates on mixing which is what will help you the most judging by your comments. https://www.youtube.com/watch?v=cHxMsawJsTc
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O Last edited by zedhed; 10-02-2017 at 02:40 PM. |
Re: Mastering Tips
Never? He specifically uses the term "master". Perhaps incorrectly? I don't know him. I know technically, and sometimes in online forums, mastering should only be done with some sort of purist approach... In my world, that's almost impossible. Roughly 50 percent of our work is sent in stems, and the clients specifically ask for us to tweak groups of tracks, pull vocals way forward or back, or as we say, "final tweak the mix". The clients generally can't remix everything due to time constraints. I know that is probably breaking some hard and fast rule, but I have never actually seen that rule. Luckily, it's not enforced as we are forced to do some pretty crazy stuff. If varying the phase of a stereo stem gets the result we all like, that's the way it is. No rules.
bookerv12 |
Re: Mastering Tips
Purist. Demagog...
We have them on the DUC. That's right. I'm no mastering pro, but I happen to help a friend now and then to finish his mixes. He sends me six or eight stereo stems and I finalize the whole thing. Call it what you want. |
Re: Mastering Tips
If you're getting good quality work, I'd call it mixing and mastering. Nothing 'purist' about that. One can polish a turd all he likes but it is still a turd, nothing 'Demagog' about that either.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Re: Mastering Tips
Now for most independent artists and hobbyist these services are blurring into mixing services making things “phat” but this not traditional mastering. Mastering is about the room and 2nd ear and getting something back that makes the track the best it can be from a technical / genre perspective. Reaching maximum impact on any system |
Re: Mastering Tips
That, and nowadays you need to take special care of the dynamics your customer is looking for. If it's mixed 14dB dynamics (meaning RMS is about -14dBFS) and it sounds great for mastering engineer but the customer walks in and says it isn't loud enough, then you just need to squeeze it into 8dB or whatever "loudness" the customer is looking for. And while doing that trying to maintain most of the quality of the mix... sadly, this is the step that people nowadays are thinking when they talk about "mastering".
MASTERING TIPS!!!! | woodbeatz | Tips & Tricks | 8 | 10-25-2004 12:41 AM |
Using the L2 And C4 For Mastering.. tips | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-14-2004 07:04 PM |
Mastering Tips | Kleekoh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 07-28-2003 04:47 PM |
Tips on Mastering Hip-hop | Hardnox | Tips & Tricks | 18 | 07-27-2003 11:39 PM |
tips for mastering | Alberto Tarin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 03-08-2000 08:09 PM |
