Edit window—waves look all wrong
Running PT 10 and suddenly my edit window looks like this. I have searched thru the options in Edit, View and Track and I am unable to find a way to change the appearance of the graphic back to normal. All tracks play normally. No idea how this change occurred.
[IMG][/IMG] SiSoftware Sandra ID Host Name : MusicMaestro Workgroup : WORKGROUP Computer Model : Apple Macmini6,2 Serial Number : C07MC3****** Chassis : Apple Lunch Box Mainboard : Apple Mac-F65AE981FFA204ED Serial Number : C0740960********* BIOS : Apple MM61.88Z.0106.B04.1309191433 09/19/2013 Total Memory : 8GB DDR3 SO-DIMM Processors Processor : Intel(R) Core(TM) i7-3615QM CPU @ 2.30GHz (4C 8T 3.09GHz/3.3GHz, 3.1GHz IMC, 4x 256kB L2, 6MB L3) Socket/Slot : FC PGA988 (G2) Chipset Memory Controller : Apple Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.6GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Elpida EBJ41UF8BDU0-GN-F 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module : Elpida EBJ41UF8BDU0-GN-F 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : Samsung SyncMaster (1920x1200, 24.0") Video Adapter : Intel(R) HD Graphics 4000 (16CU 128SP SM5.0 350MHz/1.2GHz, 320kB L2, 32MB DDR3 1.6GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.2GHz, 320kB L2, 1.4GB DDR3 1.6GHz 128-bit, Integrated Graphics) Compute Shader Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.2GHz, 320kB L2, 64MB DDR3 1.6GHz 128-bit, Integrated Graphics) Storage Devices Hitachi APPLE HDD HTS541010A9E662 (1TB, SATA300, 2.5", 5400rpm, 16MB Cache) : 932GB (C:) (D:) Seagate ST2000DM001-1CH164 (2TB, FireWire/1394/SATA300/600, 3.5", 7200rpm) : 2TB (G:) Logical Storage Devices BOOTCAMP (C:) : 465GB (NTFS) @ Hitachi APPLE HDD HTS541010A9E662 (1TB, SATA300, 2.5", 5400rpm, 16MB Cache) Glyph 4PT (G:) : 2TB (NTFS) @ Seagate ST2000DM001-1CH164 (2TB, FireWire/1394/SATA300/600, 3.5", 7200rpm) Macintosh HD (D:) : 465GB (HFS) @ Hitachi APPLE HDD HTS541010A9E662 (1TB, SATA300, 2.5", 5400rpm, 16MB Cache) Peripherals LPC Hub Controller 1 : Intel Panther Point LPC Controller Audio Device : Intel Panther Point High Definition Audio Controller Audio Codec : Cirrus Logic 4206 Disk Controller : Intel Panther Point Mobile 6 port SATA AHCI Controller Disk Controller : Broadcom NetXtreme BCM57765 Memory Card Reader USB Controller 1 : Intel Panther Point USB xHCI Host Controller USB Controller 2 : Intel Panther Point USB Enhanced Host Controller #2 USB Controller 3 : Intel Panther Point USB Enhanced Host Controller #1 FireWire/1394 Controller 1 : Lucent/Agere Systems (Was: AT&T MicroElectronics) FW643 [TrueFire] PCIe 1394b Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Epson ESC/P-R V4 Class Driver (360x360, Colour) Scanners and Cameras Scanner : Microsoft EPSON5BCA06 (WorkForce 630) (Scanner, USB) Peripherals Media Player : ST2000DM 001-1CH164 (1.82TB) Network Services Wireless Adapter : Broadcom 802.11n Network Adapter (802.11g (ERP), AES-CCMP, 54Mbps) Operating System Windows System : Microsoft Windows 8.1 Professional 6.03.9600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Re: Edit window—waves look all wrong
Hola!
Select (or deselect)View>Waveforms> Rectified. Bye. |
That.
And I have to ask - why are you running PT in Windows on a Mac? Why not just run PT in the native OSX that's on the Mac Mini? I have to admit seeing a Sandra report on a Mac is a bit weird, especially given that PT is dual-platform. |
Yep, that is rectified waveform. Some people love it, I myself hate it. Except when I need to extract silence from KICK/SNARE/TOM tracks, then rectified is king.
Hola! Thanks very much, that did the trick!
However, once I get better with PT, I may just give it a whirl. |
So you don't use OSX at all? That's a shame and a waste of money to have purchased a Mac to run Windows on. Mac implementation is so much better - you don't have crud like the Windows Registry to worry about in OSX.
Mix Window Freezes but Edit Window works fine. | wwicklund | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-10-2022 10:57 AM |
dual monitors... edit window + mix window | T-Jac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 37 | 04-23-2010 02:21 PM |
Cannot change EDIT MODE in edit window | Xavior | Pro Tools M-Powered (Mac) | 2 | 05-24-2007 12:51 AM |
Edit/Mix window placement wrong each time! | SHRED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-14-2003 07:18 AM |
tabbing in edit window, not waves | friendlybunny | Pro Tools TDM Systems (Mac) | 3 | 04-24-2003 06:09 AM |
