Old 03-21-2018, 09:53 AM
TheMusicGuy TheMusicGuy is offline
Default Clip gain enter value
Is there any key command to click and enter a numerical value to change the Clip Gain level amount in Edit window for a waveform? Currently I use shift + cntrl up/down arrows to change the volume amount. Thank you
For example, you are in Edit window, see waveform with -0.0 dB amount, you want it to be -9dB, something where you can just enter -9 on keyboard. Wish the numerical value on the waveform was active.
Old 03-21-2018, 09:57 AM
Stig Eliassen's Avatar
Default Re: Clip gain enter value
Not to my knowledge, but you can set a preference for the desired amount.
Old 03-21-2018, 11:55 AM
Thanks.
Old 03-21-2018, 12:00 PM
This will be helpful. As the video, the default .5dB is just too fine for me. Would be great to be able to toggle two values, a fine one and a larger increment one.
https://www.youtube.com/watch?v=7aM2SJAWUIQ
Old 03-21-2018, 12:54 PM
BScout BScout is offline
You can change the incremental value in preferences. (though you can't set up two values like fine/coarse)
Old 03-22-2018, 05:00 PM
Question Re: Clip gain enter value
Has someone logged this as a feature request at http://protools.ideascale.com?
Clip gain o Gain plug in Camilo Toledo Foro en Español 3 03-22-2017 02:10 PM
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
