Old 02-15-2018, 11:16 AM
zixis9 zixis9 is offline
Default DigiRack003 "What the...??"
Hello. PT11 (11.3.1) late 2012 Imac digi003 (11.1.5). Im unable, as of late, to toggle the DI switch on the 003. (once again, just recently for no apparent reason that I can determine). Start session, (sytem totally on and ready,) plug in bass DI to channel 1. as soon as I try to select DI button, it no longer stays selected, same with the monitor button. any suggestions? Thanks! Protools support is totally useless to their customer base!
Old 02-15-2018, 12:18 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: DigiRack003 "What the...??"
Does trashing prefs help?
Does a hard reset of your computer help?
Does a hard reset of the interface help?
Daniel
Old 02-15-2018, 12:21 PM
Since this is an old and unsupported product, I would not expect support to be anything other than what you already know. Having said that, the solution is actually really simple. Since it won't stay on the DI setting, just use the XLR input with a direct box. Odds are that you won't hear any difference, or it might sound better(depending on the quality of the DI box). I promise you that a good DI box will be less expensive than any repair to the 003 Given the current value of 003R's it might also be just as cost-effective to buy another one(I just picked up a mint 003R at a local pawnshop for $100)
Old 02-16-2018, 04:39 PM
Thanks Guys! I always thought of trashing prefs as a protools program helper thing, not for hardware. I trashed em anyway. No help. More investigation reveals when system is on and ready, ( haven't opened PT yet) 003 works fine as before, all the DI switches toggle as chosen. realized today that when I open PT, the switches stop responding, (Cant toggle at will). I guess OLD AGE has taken hold. Albee, I did find some on ebay. might consider a replacement. This is one of many Twilight Zone episodes on my PT ride. Thanks again!
Old 02-16-2018, 05:01 PM
YYR123's Avatar
Down grade your PT version and see if that fixes the problem
Daniel
Old 03-25-2018, 07:11 PM
sdelsolray sdelsolray is offline
I had a similar problem years ago, although it dealt with different switches. The solution was to update the firmware in the Digi003.
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
"Pro Tools quit unexpectedly" when opening (holding "n" no longer fixes it)[RESOLVED] andrew24c macOS 4 07-23-2014 07:21 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
