Old 02-08-2007, 02:58 AM
arihall arihall is offline
Default Authorizing PT LE 7.3.1 HELP!
I just bought an M-Box 2 to use with MacBook Pro (10.4.8), downloaded PT LE 7.3+1 and can't get any furter. ProTools LE is not authorized with an ilok it seems (I have activated the ilok) but with a serial number which I have received by email. So all is fine exept when I try to authorize (by starting the program and clicking on Authorize) I am asked for the ilok key (although I read somwhere that PT LE is not authorized by ilok ok). So I put the ilok key in and proceed and choose manual authorization and then a window appears with CHALLENGE/RESPONSE something and absolutely no information on what to do here.
So my question is: how do I authorize my PT LE 7.3.1 with the code I received by eamail?
Help would be very much appreciated. Thank you.
Old 02-08-2007, 07:02 AM
gibson_sg gibson_sg is offline
Default Re: Authorizing PT LE 7.3.1 HELP!
You've installed paid plug-ins that don't come with PT. that's why they are asking for authorization, you would have needed to purchase each one of those plug-ins seperately if you intend to use any of them.
You need to go to Mac HD > Library > Application Support > Digidesign > Plug-ins >
then watch what plug-ins those windows are asking for authorization. Now locate those plug-ins in your folder and drag them to the trash.
Pro Tools is probably working fine, once you hit quit, and remove all those.
Old 02-10-2007, 02:32 PM
Thank you very much for your help which helped me move a little bit further although my problem still exists.
The authorization panel opened because of some additional software launching, not because of Pro Tools as you pointed out to me. I trashed this software and it doest open any more.If everything had been ok Pro Tools would have opened after canelling the additional software's launching.
And here the real problem lies: Pro Tools wont open, it crashes. I have tried uninstalling PT 7.3.1 and installing previous releases (7.1.1) with the same results. I have repaired disk permissions (which I read somewhere could be the cause) but noting works.
If you or anyone reading this can help I would appreciate it. Thank you again.
The crash log says:
Date/Time: 2007-02-10 22:29:32.898 +0000
OS Version: 10.4.8 (Build 8L2127)
Report Version: 4
Command: Pro Tools LE
Path: /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/MacOS/Pro Tools LE
Parent: WindowServer [93]
Version: 7.1.1 (7.1.1f86)
PID: 418
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
Thread 0 Crashed:
0 libSystem.B.dylib 0x9000237a strchr + 10
1 com.digidesign.framework.DFW 0x028dbb94 TApplication::GetApplicationVersionComponents(Cmn_ PolyVector<long>*) + 84
2 com.digidesign.ProToolsLE 0x007bde62 start + 8108082
3 com.digidesign.ProToolsLE 0x007be978 start + 8110920
4 com.digidesign.ProToolsLE 0x00bf2135 start + 12516101
5 com.digidesign.ProToolsLE 0x0000273e start + 270
6 com.digidesign.ProToolsLE 0x00002659 start + 41
Thread 1:
0 libSystem.B.dylib 0x90048a47 semaphore_timedwait_signal_trap + 7
1 ...ple.CoreServices.CarbonCore 0x90cdd0ab TSWaitOnSemaphoreCommon + 163
2 ...ple.CoreServices.CarbonCore 0x90ce409d TimerThread + 87
3 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 2:
2 ...ple.CoreServices.CarbonCore 0x90ce7bad DeferredTaskThread + 57
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x028dbb4e ecx: 0x0000002e edx: 0x00000003
edi: 0xbffff5c8 esi: 0x00000000 ebp: 0xbffff538 esp: 0xbffff538
ss: 0x0000001f efl: 0x00010282 eip: 0x9000237a cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
Binary Images Description:
0x1000 - 0x11c3fff com.digidesign.ProToolsLE 7.1.1 (7.1.1f86) /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/MacOS/Pro Tools LE
0x1bb1000 - 0x1bd2fff com.digidesign.framework.CFD 7.1.1 (7.1.1f86) /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/Frameworks/CFD.framework/Versions/A/CFD
0x1be7000 - 0x1beafff com.digidesign.framework.DMC 7.1.1 (7.1.1f86) /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/Frameworks/DMC.framework/Versions/A/DMC
0x1bf3000 - 0x1bf4fff libFicClockComponent.dylib /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/Frameworks/libFicClockComponent.dylib
0x1d05000 - 0x1df4fff com.digidesign.framework.CoreFoundation 7.1.1 (7.1.1f86) /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/Frameworks/CFnd.framework/Versions/A/CFnd
0x1e7b000 - 0x1edcfff com.digidesign.framework.DSI 7.1.1 (7.1.1f86) /Library/Frameworks/DSI.framework/Versions/A/DSI
0x1f35000 - 0x1f83fff com.digidesign.framework.DUI 7.1.1 (7.1.1f86) /Library/Frameworks/DUI.framework/Versions/A/DUI
0x1f97000 - 0x1fdcfff com.digidesign.framework.DSPManager 7.1.1 (7.1.1f86) /Library/Frameworks/DSPManager.framework/Versions/A/DSPManager
0x2808000 - 0x2996fff com.digidesign.framework.DFW 7.1.1 (7.1.1f86) /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/Frameworks/DFW.framework/Versions/A/DFW
0x2aab000 - 0x2db1fff com.digidesign.framework.FileFormat 7.1.1 (7.1.1f86) /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/Frameworks/FFmt.framework/Versions/A/FFmt
0x31d5000 - 0x351dfff com.digidesign.framework.DAE 7.1.1 (7.1.1f86) /Library/Frameworks/DAE.framework/Versions/A/DAE
0x38c5000 - 0x3a71fff com.digidesign.framework.DHS 7.1.1 (7.1.1f86) /Library/Frameworks/DHS.framework/Versions/A/DHS
0x3abf000 - 0x3d95fff libNeoAccessPro.dylib /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/Frameworks/libNeoAccessPro.dylib
0x3e6b000 - 0x3f43fff libOMFToolkit.dylib /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/Frameworks/libOMFToolkit.dylib
0x3f5b000 - 0x3fa5fff com.digidesign.framework.DirectIO 7.1.1 (7.1.1f86) /Library/Frameworks/DirectIO.framework/Versions/A/DirectIO
0x455f000 - 0x45f6fff [Unknown Bundle] [Unknown Bundle]
0x5008000 - 0x509ffff [Unknown Bundle] [Unknown Bundle]
0x5192000 - 0x5229fff [Unknown Bundle] [Unknown Bundle]
0x5505000 - 0x559cfff [Unknown Bundle] [Unknown Bundle]
0x8fe00000 - 0x8fe49fff dyld 46.9 /usr/lib/dyld
0x90000000 - 0x9016ffff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x901bf000 - 0x901c1fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x901c3000 - 0x901fffff com.apple.CoreText 1.1.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90226000 - 0x902fcfff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9031c000 - 0x90770fff com.apple.CoreGraphics 1.258.38 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90807000 - 0x908cffff com.apple.CoreFoundation 6.4.6 (368.27) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9090d000 - 0x9090dfff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9090f000 - 0x90a02fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a52000 - 0x90ad1fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90afa000 - 0x90b5efff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x90bcd000 - 0x90bd4fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x90bd9000 - 0x90c4cfff com.apple.framework.IOKit 1.4.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90c61000 - 0x90c73fff libauto.dylib /usr/lib/libauto.dylib
0x90c79000 - 0x90f1ffff com.apple.CoreServices.CarbonCore 682.15 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90f62000 - 0x90fcafff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x91002000 - 0x91040fff com.apple.CFNetwork 129.19 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x91053000 - 0x91063fff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x9106e000 - 0x910ecfff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91121000 - 0x9113ffff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9114b000 - 0x91159fff libz.1.dylib /usr/lib/libz.1.dylib
0x9115c000 - 0x912fbfff com.apple.security 4.5.2 (29774) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913f9000 - 0x91401fff com.apple.DiskArbitration 2.1.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91408000 - 0x9142efff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91440000 - 0x91447fff libbsm.dylib /usr/lib/libbsm.dylib
0x9144b000 - 0x914c4fff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x91512000 - 0x91512fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91514000 - 0x9153ffff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91552000 - 0x91626fff com.apple.ColorSync 4.4.8 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91661000 - 0x916defff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9170b000 - 0x917b4fff com.apple.QD 3.10.21 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x917da000 - 0x91825fff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x91844000 - 0x9185afff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91866000 - 0x91880fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9188a000 - 0x918c7fff com.apple.LaunchServices 181 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x918db000 - 0x918e7fff com.apple.speech.synthesis.framework 3.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x918ee000 - 0x91929fff com.apple.ImageIO.framework 1.5.0 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9193b000 - 0x919edfff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91a33000 - 0x91a49fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91a4e000 - 0x91a6cfff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91a71000 - 0x91acffff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91ae1000 - 0x91ae5fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91ae7000 - 0x91b64fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91b68000 - 0x91ba5fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91bab000 - 0x91bc5fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91bca000 - 0x91bccfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91bce000 - 0x91bcefff com.apple.Accelerate 1.3.1 (Accelerate 1.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91bd0000 - 0x91c5efff com.apple.vImage 2.5 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91c65000 - 0x91c65fff com.apple.Accelerate.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91c67000 - 0x91cc0fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91cc9000 - 0x91cedfff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91cf5000 - 0x920fefff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x92138000 - 0x924ecfff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92519000 - 0x92597fff com.apple.DesktopServices 1.3.5 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x925d8000 - 0x92808fff com.apple.Foundation 6.4.7 (567.28) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92914000 - 0x929f2fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92a0f000 - 0x92afcfff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92b9a000 - 0x92b9afff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92b9c000 - 0x92bacfff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92bba000 - 0x92bc2fff com.apple.speech.recognition.framework 3.6 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92bc8000 - 0x92bcdfff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92bd3000 - 0x92c64fff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92c78000 - 0x92c7bfff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92c7e000 - 0x92c9bfff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92cab000 - 0x92cb1fff com.apple.print.framework.Print 5.1 (192.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92cb7000 - 0x92d1afff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92d3e000 - 0x92d7ffff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92da6000 - 0x92db3fff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92dba000 - 0x92dbffff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92dc4000 - 0x930b6fff com.apple.HIToolbox 1.4.8 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93d42000 - 0x93e03fff com.apple.audio.toolbox.AudioToolbox 1.4.3 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93e43000 - 0x93e43fff com.apple.audio.units.AudioUnit 1.4.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x942fe000 - 0x945b7fff com.apple.QuickTime 7.1.3 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x96021000 - 0x96024fff libLatinSuppConverter.dylib /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
0x965f2000 - 0x96628fff com.apple.audio.midi.CoreMIDI 1.5.1 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x9a952000 - 0x9a9d0fff com.tcltk.tcllibrary 8.4.7 a /System/Library/Frameworks/Tcl.framework/Tcl
Model: MacBookPro1,1, BootROM MBP11.0055.B08, 2 processors, Intel Core Duo, 1.83 GHz, 2 GB
Graphics: ATI Radeon X1600, ATY,RadeonX1600, PCIe, 128 MB
Memory Module: BANK 0/DIMM0, 1 GB, DDR2 SDRAM, 667 MHz
Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), 0.1.27
Bluetooth: Version 1.7.9f12, 2 service, 1 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Network Service: Parallels Host-Guest, Ethernet, en2
Network Service: Parallels NAT, Ethernet, en3
Serial ATA Device: TOSHIBA MK8032GSX, 74.53 GB
Parallel ATA Device: MAT****ADVD-R UJ-857, 762.08 MB
USB Device: Built-in iSight, Micron, Up to 480 Mb/sec, 500 mA
USB Device: Apple Internal Keyboard / Trackpad, Apple Computer, Up to 12 Mb/sec, 500 mA
USB Device: Bluetooth HCI, Up to 12 Mb/sec, 500 mA
USB Device: IR Receiver, Apple Computer, Inc., Up to 12 Mb/sec, 500 mA
Bombfactory BF3-A Not Authorizing The Dougfather 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-24-2009 04:14 PM
authorizing d fi?! jamieson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-23-2004 09:49 AM
authorizing my plugins!!!!!! mcg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-03-2004 03:29 PM
Authorizing D-Fi ozone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-02-2004 01:18 PM
Authorizing eljodon Pro Tools TDM Systems (Mac) 3 03-07-2002 11:03 AM
