Old 02-12-2017, 01:52 PM
Boombatty's Avatar
Boombatty Boombatty is offline
Default Import Session Data from Project
In keeping local session copies for safety:
It would be great if we could import session data from a project, rather than having to open a project, export just a few tracks as a new session, and then import from that session.
Old 02-13-2017, 01:38 PM
KR250 KR250 is offline
Default Re: Import Session Data from Project
You can do that if you select "save a copy in" from your project, then just change the format to session and save it locally.
Old 02-15-2017, 03:44 PM
Boombatty's Avatar
Yes, I am aware of that. What I'm suggesting is that if you've already done that and are working on that local copy, it would be great to simply import session data from whatever changes are made in the project from contributors into your local session without having to either do that again, and then import session data, or having to do what I explained in my original post (which would save on local HDD space).
Old 08-23-2017, 03:04 PM
acstctws acstctws is offline
I know this is an old thread, and you may have already figured it out, but I was looking for the same thing and found how to do it.
If you go to the "Open Project" Dashboard, click the downward arrow on whatever project you want to import from, and click "Open Revision History...", there's a button towards the bottom right that will allow you to import session data.
Evan Bradford
Clear Lake & Fever Recording
Los Angeles, CA
evanbradford.com
clearlakerecordingstudios.com
feverrecording.com
Old 02-21-2021, 10:49 AM
Spyderrp7 Spyderrp7 is offline
I don't see that. Clicking the downward arrow I see an option "Open Latest Auto-Backup" but that doesn't help to import session data.
Pro Tools 9 crashes every time I open a new session or import session data Ryan Butler macOS 14 03-23-2014 07:53 AM
Import Session Data with out Audio import disinfor Pro Tools M-Powered (Mac) 7 11-14-2010 11:44 AM
import session data without audio data rgalpin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-06-2010 01:49 PM
End of Stream Reached - session broken - import session data does not work... Sean Russell Pro Tools TDM Systems (Mac) 0 01-15-2010 04:56 PM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
