Reinstalling PT and the Install Menu Does Not Render
Got a new hard drive, so I am reinstalling M-Powered 8 from disc, and then I have a crossgrade I will use to update. When I run setup from the M-Powered 8 disc the install pop-up appears, but the contents of the pop-up menu don't render. I can't do anything in the pop-up window and can't continue with the install. Any ideas on a work around? I'm running Windows 7 Pro, Service Pack 1. Thanks!
Re: Reinstalling PT and the Install Menu Does Not Render
Not sure if it will help, but IIRC, there were lots of defective installer disks with LE8 and MP 8(as long as you registered it, you could probably get a fresh download from your MyAvid account). In any case, you need to open the disk(or download), find the Setup file, right-click on it and choose Run as Administrator(which actually should be done for any software install on Win7 or 10). You will likely also need the 8.0.5 updater(run as admin after you restart from the original install).
Having said that, what happened with the previous system drive? If it was working well, a disk clone might save a lot of hassle
I / O menu does not exist in the setup menu, Pro Tools First | Berry Oaks | Pro Tools 12 | 0 | 01-19-2017 01:11 AM |
Alt-menu keyboard shortcuts - Alt+F for file menu, etc. | scullionj | Windows | 7 | 11-22-2015 08:59 AM |
pro tools plugin menu, and options menu blank | lucidlife | Pro Tools 10 | 4 | 12-07-2014 12:16 AM |
Track RENDER | Kon Alexiou | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-18-2009 10:42 AM |
Menu BUG...Menu FREEZES...Menu LOCKS UP...Restart Pro Tools! | a2zproductions | Pro Tools TDM Systems (Mac) | 16 | 05-08-2008 08:30 AM |
