Old 10-16-2008, 10:35 AM
w3ird w3ird is offline
Default Assigning multiple Output Paths
Hi all,
I'm dealing with protools projects that have a lot of different tracks and busses. I was wondering if there is a way to Reassign multiple output path of track/busses at the same time? A keyboard shortcut or I dont know.... The Groups have no effects on the output path.
Thanks!
Old 10-16-2008, 11:15 AM
DigiTechSupt's Avatar
Default Re: Assigning multiple Output Paths
If you hold 'option' while clicking on a tracks output, it will change the output on all tracks. Add 'shift' to that and it only applies it to selected tracks. Add 'control' to that and it will add the selected output to the current output.
Obviously these are for Mac - swap 'Alt' for 'Option' and the Windows/Start key for 'Control' if you're on a PC.
Avid Audio Tech Support
Support FAQ
Old 10-16-2008, 12:01 PM
That was fast. Thanks!
Old 10-17-2008, 07:58 AM
And is there any way of UNDOING those track assignments? lol
Old 10-17-2008, 01:05 PM
Stig Eliassen's Avatar
Import session data from a backup session. You can import I/O assignments, and then match the tracks.
Tip - Use 'Save As...' every time you make significant changes in your sessions. Easier to go back when you need to.
Old 10-17-2008, 02:39 PM
BaileyBass BaileyBass is offline
Yes, IF I am understanding you correctly. Press Control/Option/shift.. then click the output of any of the selected tracks. You will see the outputs "checked". Click on one of those and it will release/cancel that output for all the tracks selected. SB
Old 10-17-2008, 02:51 PM
Brent_Sydney Brent_Sydney is offline
I've also gone through those and a lot more shortcuts on a blog topic
"Mixing it up in the Mix window" FYI linked here:
http://brentheber.com/?p=13
Hope that helps!
Old 06-16-2015, 03:37 AM
sijamaudio sijamaudio is offline
Oh how important this is! It's such a bugger to have to think back through all your routing if you make the simple mistake of not holding down shift.
Does this assign all outputs back to the master, or to the previous outputs they were assigned to? As I usually have plenty of tracks routed to various Aux Inputs before the master
Late 2009 iMac Core 2 Duo | 4GB RAM | Lexicon Omega | PT 10 & 11 | Logic Pro 9
Old 06-16-2015, 05:12 AM
No. What I believe BaileyBass said is that with multiple outputs assigned, you can hold Shift+Ctrl+Option and click on the output of any selected track, and click on assigned/checked outputs to remove them. The rest of the assigned outputs for selected tracks will stay.
Old 06-16-2015, 05:18 AM
Oh I see. So best make sure to save right before doing so if you're prone to hitting the wrong key commands like me!
Bussing and/or Assigning multiple tracks to same output negate OTB Summing? Myles83 macOS 1 07-23-2013 06:18 PM
Multiple Audition Paths? max cooper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-13-2008 03:15 PM
Cannot get 5.1 tracks or output paths in Pro Tools 6.4.1 Berrado Post - Surround - Video 4 06-11-2007 11:34 AM
How do I select multiple output paths? syra Pro Tools TDM Systems (Mac) 5 10-21-2003 12:39 AM
spdif assigning paths ajazzie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2002 06:04 AM
