Old 03-15-2010, 01:41 PM
shultzee13 shultzee13 is offline
Default Not understanding. Changed sample rate/Processor Numbers
Recording four separate sessions right now. 1 of the sessions I changed the sample rate and numbers of processors - changed back to normal defaults after only 1 10 second playback and now I get DAE error -7054 on the air-plug-ins - Eleven LE and Structure Free. Non air-plugs - on applying Pod Farm from Line6 gives me this error.
I have dumped all tracks to a new session one at a time and I am not getting the error on 11 but I am on Structure Free.
Loading alot of Plugs seem to also cause this error as well. The funny thing is I also get a message on 11 and Pod farm saying these are not authorized and "an ilok cannot be found."
What is going on?
PTMP 8.0.1
M-Audio Fast Track Ultra 8R
I know you need a Sandra and I don't mind posting...but I was wondering if this is a common problem that I have missed on here somewhere?
I was hoping for a quick fix I guess.
Trashing & deleting prefs and restarting computer does not resolve this.
Thanks guys.
Old 03-15-2010, 01:43 PM
Default Re: Not understanding. Changed sample rate/Processor Numbers
FYI - In the other 3 sessions where I have not changed anything (sample numbers or number of processors) all these plugs work fine. NO problems at all.
Old 03-19-2010, 10:11 AM
Could it be that the session was recorded with one sample rate and saved as another accidently?
If so, how do I rectify?
Thanks.
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up finalcut Windows 12 02-20-2012 04:00 AM
pro tools has reset the sample rate of the hw device because it was changed by anothe GHoSTFiNGeR Tips & Tricks 2 03-05-2010 10:13 AM
Peak level changed after sample rate convertion muks Pro Tools TDM Systems (Mac) 1 02-20-2009 11:19 AM
Sample Rate Changed on 48k session Mikeymike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-21-2008 06:53 PM
Bit Rate/Sample Rate problem? The chipmunks? bspro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2008 05:40 PM
