Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 06-15-2019, 10:49 PM
Barryd's Avatar
Barryd Barryd is offline
Default Duplicating a Project (save as?)
I am currently using Pro Tools first and have about a dozen offline projects currently. I have one project that I am working on that I want to experiment going in a different direction with so basically I need to duplicate it and then mess around with the copy.
Is there a way to do that? In audacity which I used to use you would just go FILE, Save AS and give it a new name. Same in Word, Excel etc.
Thanks.
Old 06-15-2019, 11:37 PM
Default Re: Duplicating a Project (save as?)
Thanks.
You would be better off posting this question in the Pro Tools First section of DUC.
http://duc.avid.com/forumdisplay.php?f=138
Old 06-15-2019, 11:39 PM
Barryd's Avatar
Is it not the same procedure for both versions? Assuming there is a procedure.
Old 06-15-2019, 11:46 PM
You are working with Projects and the mutant local version of those provided in First, not the local Sessions format that almost everybody else here uses. (I've tried to explain this to you before. And been clear that for what you are doing I would not be using First. But that is your choice). But you are likely asking in the wrong place.
Almost every user in this forum section does not use Pro Tools First, will likely have no idea what First does now with local Projects caching etc. A few users here might use Project/collaboration with Standard/Ultimate but the place you will likely get best help is the First forum.
Old 06-15-2019, 11:56 PM
And Pro Tools standard and Ultimate have Save As... and Save Copy In... (and it's Save Copy In that is the really useful one). Both well described in the Pro Tools Reference Guide. I have no idea what Pro Tools First provides.
Old 06-16-2019, 12:32 AM
Southsidemusic's Avatar
Moved it to PT|First Discussion
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 06-16-2019, 12:59 AM
Barryd's Avatar
Ok thanks. Hopefully someone who does have an idea how Pro Tools first works might answer then.
It would seem a pretty fundamental, basic and important feature really to have even in the entry level platform to this DAW.
Old 06-16-2019, 01:47 PM
DigiTechSupt's Avatar
Sorry, this is not included on the latest release of Pro Tools First. Please feel free to add this at the Feature Request section of the Pro Tools Lounge inside the Avid Link app.
Avid Audio Tech Support
Support FAQ
Old 06-16-2019, 02:06 PM
Barryd's Avatar
Ok thanks.
Old 10-26-2019, 09:37 AM
sv_guy sv_guy is offline
I was wondering where save as or duplicate session was too. Also it’s annoying that your actual session files are placed in an predetermined folder and can’t be moved. Things like this make upgrading to a $29 month subscription not worth it. Pro Tools ain’t that special. I left in 2006 to move to Ableton Live and I wanted to revisit some old Pro Tools songs. Better of just using my old G4 Mac and Pro Tools 5.1.
Save project to disk surreall Pro Tools | Intro Discussion 3 09-27-2018 12:19 PM
best way to save finished project to another drive summerbankstudios Pro Tools TDM Systems (Mac) 2 08-28-2011 01:31 PM
Project will not save!!! tkicker4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-29-2010 11:13 PM
can't save my project stefunktrumpet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-10-2009 07:08 AM
Sometimes PT5.3.1 crash when I save project polnetwork.com Pro Tools TDM Systems (Mac) 0 04-09-2003 09:13 AM
