Mojave breaks DADman software
DADman software gui is totaly unresponsive under mojave, it was fine under high sierra.
The MOM works just fine so volumes and sources selecting works fine... but the gui is not showing real live feed. Speakervolume fader is not even moving, selecting things with the mouse is not working. Uninstalled DADman software and installed it again... no go. First did a clean install with mojava... after that I tried an upgrade from high sierra were everything works fine... it breaks the dadman software anytime. So for now I stick to High Sierra... but if someone knows the problem, let me know.
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11 16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1 MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch + madi baseunit + optical SFP 1300nm MOM v.1.0.1.4 by DAD Genelec 1237A Sam, Avantone active mixcubes LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro Furman P1400 AR E Power conditioner Live-rack: 1x HD Native TB, 4x 192 I/O (64ch AD) 8x Yamaha HA-8 micpre, Rosendahl mif4, Genelec 1031A, Presonus Monitor Station |
Re: Mojave breaks DADman software
There's a warning on DAD's site that DADman does not run on Mojave.
Maybe Avid should integrate that into its notes in big, bold letters. There's nothing to fix from a user-standpoint and DAD knows.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Glad I saw this, was thinking of upgrading today.
https://lukehoward.com/ |
Thanks, I didn’t know this... I downloaded the DAD software from the Avid site, were ofcourse is no sign of this. From now on I will check the DAD site too.
Pro Tools macOS Mojave (10.14) is supported with Pro Tools 2019.5 and higher. Note that the DADman software for Pro Tools | MTRX is not supported with macOS Mojave at this time. We´re also stuck with this as we had to buy a new MAC which came installed with Mojave. We have the new monitoring page on PT Control app but DADMan is not compatible and most stuff doesn´t work as you´ve mentioned. I don´t understand why AVID announces PT compatibility with Mojave as let people that bought it´s most expensive interface MTRX out in the dark. Just because they are not the manufacturers of the MTRX and it´s associated software, it´s not an excuse for their responsability. No wonder why people are switching to Windows...
Regards, Paulo M MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura Protools Studio 2024.3 |
Thanks for pointing out that Dadman is not Mojave compatible. I am in the process of upgrading our facility to PT2019.5 and Mojave but without Dadman support, it is a real problem for some of our rooms.
Avid, is there an ETA on Dadman support for Mojave?
Roy Machado Dallas Audio Post |
I'm having mixed results with DADman and Mojave, a combination of rebooting my S6 and reloading profiles can get DADman talking with the S6 and MTRX. Not ideal, but this is why I upgraded on a cloned hard drive and not my internal hard drive.
-Jeff |
But that isn't the DADman problem with Mojave which appears to be UI related (so Eucon control still works behind the scenes.) Your problem is something else Avid needs to fix.
This is the workaround for this. The S6 thing is a lot worse. It's like it refuses to grab DADman's info (though some of the things are working even if the GUI is not updated.) And no repeatable order of events seems to get it to work again (tried a bunch of different ways.) At some point, something just triggers it to work again and it will finally work again with the S6 completely. And once it does, it stays locked (until a reboot). I was trying to write up instructions for what to do for others who use our S6 but had to give up because there's no direct instruction to give other than keep trying to close and restart DADman while the monitoring screen is visible until it works. And having Pro Tools off until it does seems to help.
MTRX Reference (Ref) Button in DADman Software | jb_trm | Pro Tools | MTRX & MTRX Studio | 5 | 05-25-2022 02:08 PM |
Mojave? | hanksinclair | Artist Series | 3 | 05-03-2019 03:19 PM |
DADman/PROmon on MTRX with OSX above 10.12 Sierra | paulo m | Pro Tools | MTRX & MTRX Studio | 4 | 03-01-2019 04:05 PM |
Mojave ? | Riquier | macOS | 89 | 02-26-2019 06:41 PM |
Sum and Intercancel between MTRX DADman and S6 | laki | Avid S4/S6 | 1 | 12-27-2017 04:18 PM |
