Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 07-12-2017, 12:52 AM
qtvaudio qtvaudio is offline
Default MC524 not responding to serial
Hi S5 people
I'm stuck on build at getting the MC524 to work. I've taken the unit to a working facility so I know it's not a faulty unit.
I'm certain I have the 90 pin audio wired correctly
But...it's not passing audio to my monitors
I've run a 40m db15 cable from control room to mcr...pretty sure this is not the problem
The Serial Port Activity LED on the MC524 board(s) is not responding to commands from the console; it did when I tested it on the other system5, which leads me to believe there is an issue with either a set up/ configuration for the TCC board on the system computer or that the TCC board is faulty.
I've looked at the device manager on the System PC, but it's unclear which device is the actual TCC board...does anybody know?
Guidance on installation of this unit in the Euphonix/Avid guides amounts to a few sentences, and certainly cover troubleshooting this unit.
I'm at a loss...any and all suggestions greatly appreciated
Robin
Old 07-12-2017, 01:03 AM
Default Re: MC524 not responding to serial
Bump
Old 04-27-2018, 08:10 PM
Scott_Pilgrim Scott_Pilgrim is offline
Have you tried re-seating the boards?
Old 06-27-2018, 09:14 AM
Yep, replaced batteries, reseated boards, good cable, updated to emix 6.1
Old 06-28-2018, 06:48 PM
EddieJones's Avatar
Have you tried a short cable and see if the serial lights work ?
Old 07-05-2018, 03:38 AM
NExt move
Old 12-04-2018, 12:49 AM
This was finally resolved by installing a replacement TCC board. There IS still an issue with audio routing through the MC524...I'll open a new thread on this
Maximum distance between System PC and MC524 Monitoring unit qtvaudio System 5 1 07-12-2017 12:53 AM
MC524 Alternatives? audiobee System 5 3 08-26-2016 08:24 AM
Serial Card and Serial ATA...Good Idea or NoCigar fifty8th1 Pro Tools TDM Systems (Mac) 7 02-09-2005 11:24 PM
USB to serial adaptors or PCI to Serial.. maxserg Pro Tools TDM Systems (Mac) 2 10-29-2001 08:35 PM
Keyspan Serial Adapter or Keyspan Twin Serial... J. S. Bach General Discussion 0 03-20-2000 09:34 AM
