PreSonus StudioLive
Any suggestions on how I can get my StudioLive to interact w/ my PT9? For some reason when I move my faders up/down on my console it won't do it on my DAW.. Even though I have all my channels routed correctly & it works on my StudioLive software..
ALSO! I have my output in PT9 routed to channels 15/16 linked in stereo, & i want to be able to MUTE those channels during recording, but when I mute them, I can't hear anything from my headphones, is there anyway to MUTE the main monitors & have the music still playing in the headphones? I have my XLR OUT's L/R to my main monitors, & also the TRS OUT's L/R connected to my headphone amplifier/distributor.. Would appreciate any replys! I'm coming from an MBOXMini so excuse me if this is a NOOBish question.. |
Re: PreSonus StudioLive
Look In The "Peripherals Set Up" In PT To Get Your Board Talking To PT..... Once You Figure That Out...
Set Up A Head Phone Mix Using Bussing In PT.... Assign That Buss To Your Que Mix..... Then, To Your Head Phones On The SL. Hate To Say This, But You Have To Go Read Your Manual.... Then, Figure Out How The Studio Live And PT's Interact... |
According to the thread below, the StudioLive cannot be used as a control surface with Pro Tools, only as an interface.
http://duc.avid.com/showthread.php?t=289443 But if it can it will most likely be through HUI emulation, in which case have a look at Setup > Peripherals, go to the MIDI Controllers tab and select "HUI" under "Type". Check if the StudioLive shows up under the "Receive From" and "Send To" menus. Hope this helps. |
PT 11 with Presonus Studiolive 24 | daaebro | Pro Tools 11 | 8 | 02-18-2014 05:58 PM |
PT 11 and Presonus StudioLive ? | David Every | Third Party Interfaces | 7 | 08-18-2013 04:06 PM |
Presonus Studiolive 16.4.2 and PT 10 | marko_salo | Pro Tools 10 | 0 | 08-17-2013 10:49 AM |
PreSonus StudioLive 16.4.2 | danander11 | General Discussion | 5 | 08-31-2012 05:51 AM |
Presonus StudioLive with PT9 | teacherman | Pro Tools 9 | 3 | 01-22-2011 06:32 PM |
