Old 09-07-2010, 08:29 AM
Boe Larsen Boe Larsen is offline
Default Detach midi editor
Hi DUC
How is it that you detatch the midi-editor, so it doesn't come up as a part of the edit window when you double click a midi-part. I want it as a seperate window... it was like that 5mins ago... now I cant get it back
Best,
Boe
Boe Larsen
Producer
www.millfactory.dk
Old 09-07-2010, 08:38 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Default Re: Detach midi editor
PT remembers, what kind of window was last opened and opens this again
'cntrl =' opens the midi-editor as a seperate window, if you then double-click on a midi-region, the seperate midi-window will come up again
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 09-07-2010, 09:00 AM
Thanks. Saved my day
Boe Larsen
Producer
www.millfactory.dk
Old 08-12-2017, 07:11 PM
dg27's Avatar
dg27 dg27 is offline
I cannot for the life of me get this to work. I use two screens and despise when I accidentally open the MIDI window at the bottom of the Edit window. Usually I can get rid of it but I have been trying for half an hour and nothing works: I want it to open as a separate window as it normally does.
Old 08-13-2017, 08:24 AM
EdwardWilliam's Avatar
EdwardWilliam EdwardWilliam is offline
You're referring to the docked MIDI window that is attached to the Edit window? Look right above the solo and mute (S - M) buttons in the docked MIDI window. Do you see two white arrows, one pointing left (or right) and one pointing down? Click the arrow pointing down to close the docked MIDI window.
Edward
Old 08-13-2017, 12:41 PM
dg27's Avatar
Yes--I meant the the docked window on the edit screen.
Thanks--I will try your suggestion Last night after closing it several times and restarting PT it eventually opened in a separate window.
I wish there was a way of setting a preference so that it always opens in a separate window.
Old 08-13-2017, 08:48 PM
I rarely use the docked midi window, and as tonwurm described, the separate midi window opens when I double click a midi clip.
Edward
Old 09-20-2017, 01:25 AM
misterphoneman misterphoneman is offline
Hi, I've played with the "Ctrl =" and also double clicking a midi clip in efforts to get a detached window and all that is fine but every time I select the "Open in MIDI Editor" tool, it still defers back to the docked window and I have to do those undocking steps all over again. Does anyone know how to turn the docking option off for good and make it work the way it used to??
Old 02-10-2018, 04:58 PM
dg27's Avatar
I'm having the same issue right now.
The docked window is the stupidest feature I have found in PT. I find it completely pointless.
The double clicking in a midi region (for me at least) does not open the editor in a separate window.
Old 02-11-2018, 06:00 AM
Have you tried right clicking on the MIDI region and selecting 'open in MIDI editor'? Works for me and it comes up in a separate floating window.
Jack
QAPLA!
MIDI - re-spell accidentals in Score Editor, and MIDI zoom nhwinni Pro Tools 9 4 09-08-2011 10:14 AM
Can anyone clarify 1) Midi Track Sizing, and 2) color coding Midi Editor Infiltrator Pro Tools 9 5 01-10-2011 07:53 AM
Can i detach windows in PT? Dan-Jay General Discussion 4 03-06-2010 09:08 PM
Calling all that write/program midi drums by hand in the Pro Tools midi editor. Mikey Ace Virtual Instruments 2 10-05-2008 07:14 PM
detach firewire without quitting pt? eastcote Pro Tools TDM Systems (Mac) 2 11-09-2004 12:54 PM
