Old 01-16-2018, 03:59 PM
boozooq boozooq is offline
Default Re: (SOLVED) BUG:Can't access all busses (not visible on screen)
hi,
still have the issue.
The hardware is the same as in my initial post and i upgraded to PT12 and WIn10.
I use the integrated HD3000 in my motherboard and a asus GTX570.
Old 06-15-2020, 12:35 PM
chrismeraz chrismeraz is offline
Same thing here. One screen above the others messes with the outputs list and I can't access some busses. I had to move it to the side, even though it's still physically located above the others. Shame.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 12-07-2021, 07:27 PM
Songster Songster is offline
Same here ... it seems that when two monitors are positioned above one another in the Display settings in Windows, PT doesn't know where the bottom of either screen starts and stops. When side by side, it folds the lists correctly. The thing that gets me is that the AVID lists have an arrow at the top and bottom to scroll no matter what screen or window is used, but the same doesn't apply to the Bus list or the WAVES plugin list. That tells me they know how to make it work but don't have the programing needed in PT to address it. Should be a relatively easy fix for a good programmer since it already exists in one section of the code ... :
Old 03-07-2022, 11:34 AM
Skwaidu Skwaidu is offline
2022 is saying hi - still the same bug from 2008.
I have 3 monitors but they are not positioned on top of each other in windows. I'm using a GTX 960 for GPU, iGPU is not in use. Newest supported drivers for that old (temporary) GPU.
These days, one can circumvent this a lot with the search fields, but there isn't one for "route to track", for instance...
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
PT 8.0.3 + P6TD Deluxe + Intel i7 + Win7 64bit - Blue Screen (Solved). Hemophagus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-09-2010 09:08 AM
A-E sends not visible Studio Studio Pro Tools TDM Systems (Mac) 3 02-20-2009 03:02 AM
SOLVED>>Need HELP, SUPER ASAP.< audioindo Pro Tools TDM Systems (Mac) 18 04-21-2007 05:43 AM
Access Violation error issue solved daeron80 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-11-2006 03:52 PM
Can't access nudge popup:screen too small? Billy Mayhem Digidesign Hardware & Software 1 06-15-2004 09:28 PM
