Wave burner pro- Different speeds
My waveburner pro is converting but usually at a faster tempo and higher pitch. It works sometimes but lately it's messed up. Do I have to change the hardware from optical to internal before I bounce interlaced files to disc? I've tried this and I don't think that's the problem.
[img]images/icons/confused.gif[/img] |
Re: Wave burner pro- Different speeds
Somewhere is a sample rate mismatch... you should switch to internal.. but if the files were bounced down with the wrong sample rate in the header.. things will be screwey.
If everything were done right.. and you BTD'ed at 44.1kHz with the clock set externally or internally at 44.1kHz, then when you use WB, you should switch to internal. Rail
Wave Burner Pro | ajazzie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-28-2003 09:04 PM |
crashing problems with PT, Reaktor and Wave Burner | Anibal | Pro Tools TDM Systems (Mac) | 3 | 11-09-2002 09:34 AM |
Wave Burner-Type software for Lacie Burner? | Loftman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-04-2002 11:08 AM |
substitute for Wave burner pro | ongaku | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-07-2001 06:53 AM |
Question Toast, Jam, Wave Burner Pro | Azrael | Pro Tools TDM Systems (Mac) | 4 | 05-25-2001 03:11 PM |
