Old 03-07-2019, 04:55 PM
CalebCuzner CalebCuzner is offline
Default Re: Korg nanoKONTROL2 not working in CC mode with Pro Tools
Originally Posted by L J Blackler View Post
Thanks so much for your reply.
I wonder if you mistyped the model of the item that works for you, "Akai MPK mini"
that seems to not have any faders at all.
If that is the unit you are now using, are you assigning and turning the knobs to trigger changes in expression (cc11) etc ?
Yes I'm using knobs instead of faders. I typed the correct model. The knobs control my cc's and I'm using the pads for key switches.
Old 09-02-2020, 01:50 PM
Pegasussongs Pegasussongs is offline
Originally Posted by CalebCuzner View Post
The only way I could get it to work was to sell my nanoKONTROL2 and get an AKAI MPK mini instead. The nanKONTROL2 never worked but the AKAI MPK worked right away.
hi there I have experienced exactly the same issues as you.
never normally get stuck on technical issues but my goodness this has been a disaster.
could you possibly tell me if you managed to be able to write you own CC controls on your AkAI - ie could you assign plugins: Kontakt etc to the controller?
thank you in advance!
Old 05-04-2021, 09:34 AM
Joe Egan Joe Egan is offline
I set the NanoKontrol2 as indicated in the instructions to HUI, etc.
What I guessed at, was I had to undue the MIDI Control Peripheral back to none, then open up the NanoKontrol2 from the applications folder to factory Settings folder to nanoKONTROL2 Scene Data.nktrl2_data.
Now CC changes and operations with the NanoKontrol2 work fine.
Old 03-05-2022, 10:48 AM
levelaudio levelaudio is offline
Has anyone figured out how to use the nanoKONTROL2 with Soundtoys plugins via the MIDI map function? I saw in another post that it needs to be added in peripherals/MIDI controllers. I saw somebody set it up like that using M-Audio Keyboard for the controller type, with IAC port for the receive from/send to assignments. That enables the display and functionality of the MIDI map on plug-in windows. But if I set the nanoKONTROL2 up that way, I can't get it to work.
Korg Taktile Pro tools 11 controller not working markmcd357 Pro Tools TDM Systems (Win) 1 11-19-2014 02:42 PM
nanokontrol2 and pro tools express hotpies Third Party Interfaces 1 09-03-2014 10:40 AM
Working with Pro Tools 10, Korg and Mbox Pro ionactive Pro Tools 10 3 03-22-2013 11:17 PM
Korg nanoKONTROL2 David2934 Eleven Rack 0 01-03-2013 12:58 AM
Pro Tools 10 with Korg NanoKontrol2...? Vaernima Windows 5 02-23-2012 04:34 AM
