Old 10-15-2008, 09:22 AM
Mark Wheaton Mark Wheaton is offline
Default Ethernet Error
Please see bottom of this thread Page 3 for new PT 8 info!!
I have this problem with my Ethernet connection to my D-Command.
I have the updated D-Command firmware as of Pro Tools HD 7.4cs7
I have OSX 10.4.11
When I have to force quit Pro Tools (usually due to a VI freeze)
And, I do not restart my computer and D-Command
I get this dialog after relaunching Pro Tools:
An Error occurred while trying to establish Ethernet commmunications. Please check all Ethernet connections.
I click OK, the same dialog comes up a second time and then I am in Pro Tools with the ethernet connection to the D-Command turned off. If I go to the Peripherals Dialog and attempt to reconnect, I get the same message.
I must at this point restart the computer and reboot the D-Command for the dialog to go away and have the connection to D-Command restored.
Old 10-15-2008, 11:03 AM
DigiTechSupt's Avatar
Default Re: Ethernet Error
Have you tried going to the Network control panel and toggling on/off the ethernet connection, or having it renew the DHCP lease by clicking on 'Advanced' and then on the 'Renew DHCP Lease' button?
Avid Audio Tech Support
Support FAQ
Old 10-18-2008, 10:48 AM
I will try this, but I have not been getting the freeze ups that cause this in the last week. Hopefully for unknown reasons, problem solved...HaHA
Old 10-19-2008, 04:46 PM
More info on this error as it has shown up again.
I did have another crash out of Pro Tools due to a beta test I was doing and when I relaunch Pro Tools with out a restart of both the Computer and the D-Command I still get this error.
I have also had incidents in the last few days where I did a legal Quit of Pro Tools, did not restart and got the same error.
This error does not go away by restarting the Hub between my D-Command and my Computer. It does not go away by adjusting anything as described by Digi in the Network Control Panel. If I go through the two dialogs, Pro Tools completes it's launch with no D-Command.
When you go to the Peripherals and try to re-establish you get the same error.
the only workaround is a complete reboot of Pro Tools and the D-Command.
Old 10-20-2008, 10:42 AM
Can you use the Tech Support Utility to post a list of installed plug-ins (you can find the TSU in the General Troubleshooting thread..)?
I suspect you may have an incompatible plug-in installed.
I would be curious if you tested this from a new Administrator account if you still have the problem - this would help identify if it's something about your current account causing the problem.
Support FAQ
Old 10-22-2008, 01:36 PM
I did the Version test and I have the text file, should I attach that to an email or just post in a reply?
Old 10-27-2008, 02:28 PM
Please post it in your reply.
Support FAQ
Old 10-28-2008, 08:57 AM
Tue Oct 21 21:37:14 PDT 2008
Pro Tools Version
__________________________________________
Pro Tools HD.app
7.4cs7, Copyright 1991-2007 Digidesign, A Division of Avid Technology, Inc.
Plug-In Versions
Access Music Indigo.dpm
7.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Amp Farm.dpm
3.10, Copyright 2006 Line 6
Analog_Channel_HD.dpm
3.2x18, Copyright 1998-2007 McDowell Signal Processing, LLC
Atmosphere RTAS OSX
Atmosphere 1.2 Copyright Spectrasonics. www.spectrasonics.net
Atmosphere.dat
Auto-Tune_Evo_TDM.dpm
6.0.5, Copyright © 2008 Antares Audio Technologies
B4 II.dpm
2.0.4, Copyright © 2005 Native Instruments
B4 II.mopi
2.0.0, Copyright © 2003 Native-Instruments
Band Delays (Anth 2.0).dpm
1.3.2 (Anthology II), Copyright 1991-2008 Eventide, Inc.
Chorus.dpm
Click.dpm
DigiReWire.dpm
7.4, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Dither.dpm
Dynamics III.dpm
7.4cs2, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
EQ III.dpm
Elastic Audio.dpm
Flanger.dpm
GuitarRig 2.dpm
2.2.2
GuitarRig 2.mopi
2.0.2
H910 Harmonizer (Anth 2.0).dpm
1.4.2 (Anthology II), Copyright 1991-2008 Eventide, Inc.
H949 Harmonizer (Anth 2.0).dpm
1.4.3 (Anthology II), Copyright 1991-2008 Eventide, Inc.
IXL Level Meter (H).dpm
IXL Level Meter (H) v1.2x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
IXL Level Meter.dpm
IXL Level Meter v1.2x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
IXL Multimeter.dpm
IXL Multimeter v1.2x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
IXL Spectrum Analyzer.dpm
IXL Spectrum Analyzer v1.2x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
IXL Statistics.dpm
IXL Statistics v1.2x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
IXL Stereo Analyzer.dpm
IXL Stereo Analyzer v1.2x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
Instant Flanger (Anth 2.0).dpm
Instant Phaser (Anth 2.0).dpm
Invert-Duplicate.dpm
Kontakt2.dpm
2.2.1, Copyright © 2005 Native Instruments
KontaktPlayer2.dpm
2.2.4, Copyright © 2007 Native Instruments
L2007 Mastering Limiter.dpm
1.3.4 (1275) "Copyright (C)2006-2007 Massey Plugins Inc., All Rights Reserved."
Line 6
LoFi.dpm
MC2000_HD.dpm
MDW_EQ2_3B.dpm
2.0.2r44, Copyright 2007 Massenburg Design Works.
MDW_EQ2_5B.dpm
MOTUAudioFeeder.dpm
1.0x0, Copyright 2006, Mark of the Unicorn, Inc.
MachFive2 RTAS.dpm
2.0.2, Copyright 2007 MOTU
Massey TD5.dpm
1.1.3 (1287) "Copyright (c) 2007 Massey Plugins Inc., All Rights Reserved."
Massey Tools.dpm
0.5.0 beta r1537, Copyright (c) 2007-2008 Steven M. Massey, All Rights Reserved.
MasterX3.dpm
MasterX3 4.0.01 © 2006 TC Electronic A/S - All rights reserved
Melodyne plugin.dpm
Melodyne plugin 1.0.3.1 Copyright 1999-2008 Celemony Software GmbH
Mod Delay II.dpm
Multi-Tap Delay.dpm
Normalize-Gain.dpm
Octavox (Anth 2.0).dpm
1.3.1 (Anthology II), Copyright 1991-2008 Eventide, Inc.
OmnisphereWrapper.dpm
1.6b5, Copyright 2006 Spectrasonics
Ping-Pong Delay.dpm
Pitch.dpm
Play.dpm
Plug-In Settings
Quadravox (Anth 2.0).dpm
1.1.2 (Anthology II), Copyright 1991-2008 Eventide, Inc.
RA
1.0.8, Copyright © 2005 Native-Instruments
ReVibe.dpm
RectiFi.dpm
Reverse-DC Removal.dpm
SciFi.dpm
Signal Generator.dpm
SignalTools.dpm
SoundToys
Stereo Dithered Mixer.dpm
Strike.dpm
1.0.2.6036 Copyright 2008 Digidesign, A Division of Avid Technology, Inc.
Structure.dpm
1.0.1.5316 Copyright 2007 Digidesign, A Division of Avid Technology, Inc.
Stylus RMX Wrapper
Stylus RMX Wrapper 1.5 © 2005 Spectrasonics
Surround Dithered Mixer.dpm
Tape-Head.dpm
1.3.2:1201 " Copyright (c) 2006-2007 Steven M. Massey, All Rights Reserved."
Time Comp-Exp-Pitch Shift.dpm
Time Shift.dpm
7.4, Copyright © 2005 by Digidesign, a division of Avid. All rights reserved.
TimeAdjuster.dpm
Trilogy RTAS OSX
Trilogy 1.2 Copyright Spectrasonics. www.spectrasonics.net
Trilogy.dat
Trim.dpm
VariFi.dpm
Velvet.dpm
1.0.0.2944 Copyright 2006 Digidesign, A Division of Avid Technology, Inc.
WaveShell-DAE 6.0.dpm
Xpand!.dpm
1.0.1.989UB Copyright 2005 Digidesign, A Division of Avid Technology, Inc.
iZRXDeclickerPTHook.dpm
1.0.6, Copyright © 2001-2008 iZotope, Inc.
iZRXDeclipperPTHook.dpm
iZRXDenoiserPTHook.dpm
iZRXHumRemovalPTHook.dpm
iZRXSpectralRepairPTHook.dpm
vt3.dpm
"1.2.0f, Copyright (C)2006-2007 Steven M. Massey, All Rights Reserved."
Plug-Ins Unused Versions
Absynth 3 RTAS
3.0.200, Copyright © 2005 Native-Instruments
AmpliTube
AmpliTube v1.2
AntaresFilter_RTAS_OSX
1.0 ©2003 Antares Audio Technologies. All Rights Reserved.
Aphex Aural Exciter.dpm
Aphex BigBottom Pro.dpm
Auto-Tune_TDM.dpm
5.1.0, Copyright © 2007 Antares Audio Technologies
D-Verb.dpm
Drawmer Dynamics.dpm
Drumagog.dpm
1.0x0, Copyright 2006 FXpansion Audio UK Ltd..
DrumagogFL.dpm
E-Channel (Anth 2.0).dpm
1.1.1 (Anthology II), Copyright 1991-2008 Eventide, Inc.
EQ45 (Anth 2.0).dpm
EQ65 (Anth 2.0).dpm
Echo Farm.dpm
2.30, Copyright 2006 Line 6
Eventide Reverb (Anth 2.0).dpm
Factory (Anth 2.0).dpm
1.2.2 (Anthology II), Copyright 1991-2008 Eventide, Inc.
FilterBank_HD.dpm
4.2x18, Copyright 1998-2007 McDowell Signal Processing, LLC
Focusrite d2.dpm
Focusrite d3.dpm
Impact.dpm
MASTER X3
v3.7, ©1996-2003 TC Works.
All Rights Reserved Worldwide.
Massey CT4 Demo.dpm
1.0.0r2, ©2006 Steven M. Massey, All Rights Reserved.
Massey DeEsser Demo.dpm
1.0.0 [1647] "Copyright (C)2008 Massey Plugins Inc., All Rights Reserved."
Omnipressor (Anth 2.0).dpm
PTA (Anth 2.0).dpm
Play.dpm
Pluggo-RTAS.dpm
Pluggo-RTAS, Copyright ? 2006 Cycling '74
Pultec EQH-2.dpm
Pultec EQP-1A.dpm
Pultec MEQ-5.dpm
Reaktor5.dpm
5.1.0, Copyright © 2005 Native Instruments
Reaktor5.mopi
Slightly Rude Compressor.dpm
Smack! TDM.dpm
SonyOxfordEQ.dpm
2.6.2, Copyright 2007 Sonnox.
Source-Live.dpm
1.0x0, Copyright 1991-2005 Digidesign, A Division of Avid Technology, Inc.
Stereo Mixer.dpm
Stylus RTAS OSX
Stylus 1.0.6
Surround Mixer.dpm
SurroundScope
1.2, ©2000-2003 Digidesign, A Division of Avid Technology, Inc.
THC.dpm
1.0.4 (1285) "Copyright (c)2006-2007 Massey Plugins Inc., All Rights Reserved."
TL EveryPhase.dpm
TL InTune.dpm
TL MasterMeter.dpm
TL Metro.dpm
TL Space.dpm
Ultra-Channel (Anth 2.0).dpm
Vinyl.dpm
1.7.2, Copyright © 2006 iZotope, Inc.
Vocal_WaveShell-DAE 1.1
1.1, © 1991-2006, Waves Audio Ltd. All Rights Reserved.
test unused
Toolkits and Digitranslator Versions
Music Production Toolkit is not installed
DV Toolkit 2 is not installed
Digitranslator 2
7.4, Copyright 1991-2005 Digidesign, A Division of Avid Technology, Inc.
Digitranslator 1 is not installed
Old 10-29-2008, 09:51 AM
ishur ishur is offline
Don't know if this will help you, but I had this error recently, and trashing preferences and repairing permissions fixed it. It's quick, painless and worth a try...
Old 11-23-2008, 07:04 PM
Hello Digi I posted the list of plug ins and have not heard back. By the way, the delete prefs voodoo does not solve the issue.
Error find ethernet port for C24 in PTHD10 BMSS ICON & C|24 0 10-19-2012 04:50 AM
7.4cs10 update - ethernet error Felix Rost Pro Tools TDM Systems (Mac) 4 08-20-2009 01:47 PM
Procontrol/Ethernet Error. Help anyone? Ru_C Pro Tools TDM Systems (Mac) 7 06-30-2008 12:49 PM
G3 + 001 + G5 + Ethernet? dreamers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-21-2005 10:44 PM
error occured while trying to est. ethernet conn.? Plantation Studios ICON & C|24 3 10-11-2003 05:27 PM
