Old 05-19-2013, 08:59 AM
Cal D Cal D is offline
Default Faders won't move
Hi:
I am wondering if anyone can help me with this. All of a sudden, my faders on my virtual mixing window in Pro Tools, will not allow me to move them up or down with my mouse. I don't think i changed any settings, but all of a sudden this happened.
Thank-you for your help.
Old 05-19-2013, 10:31 AM
Meads Meads is offline
Default Re: Faders won't move
Can't you move them? Or will they jump back, once you moved them?
The latter is, because there's one or more automation breakpoints in your volume automation.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 05-19-2013, 11:08 AM
Hi Meads:
They won't move at all. I also have a Korg nanoKontrol2 hooked up (a hardware interface). The sliders will move using the hardware control, but not with my mouse. Up till now, either worked.
I also checked other session files and the sliders cannot be moved by the mouse on all of them. I have had the automation issue before, but this is not the same.
Old 11-29-2014, 09:14 PM
Bunglespice Bunglespice is offline
Did you never find a solution for this? I have suddenly been faced with the same issue. In my ProTools sessions I'm unable to select solo, mute, or move the virtual faders at all. It is as though they are olocked. I'm also unable to get the faders to move on my controller. Oddly enough I am still able to add tracks, change inputs and change automation. This has affected every single ProTools session I have. Any ideas? I'm kinda dead in the water without these.
For my setup I'm using ProTools 9, two Profire 2626s for my interface and two BCF2000s for my controllers.
Thanks in advance.
Old 11-30-2014, 07:48 PM
Actually nevermind. After further research ity was determined that the driver simply didn'tg load when initializing Pro Tools. I had to do a few full restarts before it started working again. Frustrating, but recoverable.
Thanks anyway.
Faders won't move DontLetMeDrown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-07-2007 11:26 AM
move all faders at once CHEEZGRITS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-16-2005 09:41 PM
002 Faders Don't Move Brand X 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-13-2003 08:01 AM
anyone using an 03D to move faders in PT? noize Pro Tools TDM Systems (Mac) 1 10-01-2002 12:52 AM
Faders don't move.. Michael Knox ICON & C|24 5 07-16-2002 08:13 AM
