Old 12-22-2003, 03:02 PM
derF derF is offline
Default Error Code -50 When copying to Firewire HD
Anybody know what this is???? I keep getting it when copying stuff from internal HD to Firewire. "Cannot copy due to error code -50". It has happened on two different macs (running OSX) and with 4 completely different drives (EZQuest, LaCie norm & PocketDrive, Quantegy)
It's very annoying, especially as the drives always have MORE than enough free space. It is not consistant either. It'll copy onto one drive, but not another.
Apple site doesn't even recognise an error code -50. Only 51! What is that all about???!!!!
Really don't want to have to wait for a DVD-R to burn every time I want to move stuff around. Isn't that the idea of Firewire?????
Old 12-22-2003, 04:45 PM
Default Re: Error Code -50 When copying to Firewire HD
Anybody???
I have tried running Disk Utility on both drives, repairing permissions. Also, Disk Warrior 3 on both, but still nothing..........
Old 12-22-2003, 05:28 PM
How did you format the drives? Did you follow the Digi directions in the AnswerBase?
A OS9 error -50 is paramErr - Error in user Parameter list
Sounds like it's permission related.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-24-2018, 06:45 PM
AmyBuckland620Yr AmyBuckland620Yr is offline
Error code 50 on Mac might be related to hardware issues. Therefore, you may need to reset the Parameter RAM (PRAM) or/and system management controller (SMC). However, you should opt for this option only if none of the above methods have worked for you.
Before following the instructions below, you should backup your system or important data only in order to avoid possible information loss.
Follow these steps to reset PRAM:
Turn of your Mac.
Press the power button.
Immediately hold down the Command + Option + P + R keys until your computer reboots, and you hear the startup sound TWICE.
Once you hear the sound, you can release the keys. The PRAM has been reset.
In case, all the above steps will not work to fix this Mac error code 50, then you should Check this URL.
https://www.errorsolutions.tech/error/error-code-50/
Old 04-25-2018, 12:36 AM
Sardi Sardi is offline
Woah!
15 year thread bump to post a reply.
That must be a forum record.
os10.3.5 (error code -36) when copying files to dv Kris Pro Tools TDM Systems (Mac) 10 02-27-2007 06:44 PM
Error -36 when copying pro tools sessions from DVD Killah Kane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-14-2007 07:38 PM
-39 error when copying session Breck Post - Surround - Video 5 05-17-2006 11:58 AM
Firewire copying problem Siegfried Meier Pro Tools TDM Systems (Mac) 3 12-18-2003 08:45 AM
Error code 9073 / OWC Firewire Drive 8Ball_Studio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-11-2002 12:54 AM
