Old 11-23-2015, 01:11 PM
EddieJones's Avatar
EddieJones EddieJones is online now
Default Cleaning S6 Surface
This Plexi Clean seams to do a great job of cleaning the S6 surface including the screens. It cuts down on finger prints too. Obviously be careful in its application, turn the system off, use a soft bristle brush first to dust off the surface, then spray this onto soft cloth and polish off.
http://www.amazon.com/Blue-Ribbon-Pl...ds=plexi+clean
Old 11-24-2015, 07:53 AM
Postman Postman is offline
Default Re: Cleaning S6 Surface
Thanks for the suggestion! I want to try it to see if it works as well as what I've been using, which is more expensive. Novus #1 Plastic Clean and Shine takes away fingerprints and leaves an anti-static surface. Works nicely on the screens also. Novus #1 is not abrasive.
Novus also makes plastic scratch removers #2 (fine) and #3 (coarse) which MIGHT come in handy in the future. I have used all three products on antique plastic, cataline, bakelite, etc. Use #3 for deep scratches followed by 2 for surface scratches. #2 leaves a high shine, followed by #1 to finish and preserve.
For S6 textured sides and back I've been very satisfied with Bona laminate floor cleaner. The textured plastic traps all sorts of particles when rubbed with anything. Once Bona cleaned and dry, a vacume will remove those particles.
system specs in profile
Old 11-24-2015, 08:11 AM
EddieJones's Avatar
Be careful with these, the top surface has a hardened layer on the top and this may remove that and make things worse.
Old 11-24-2015, 09:21 AM
Ah, wow, that's interesting and good to know. Ignore than I said anything about #2 and #3!
Old 11-24-2015, 08:35 PM
lucienpalmer lucienpalmer is offline
Thanks, Eddie. That's a really helpful post. I've been too nervous to use anything on fingerprints other than a cleaning cloth for eyeglasses.
On a related note, a Swiffer Duster works wonders for daily dusting. It's like a magnet. Easy to run between the knobs and faders.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 11-25-2015, 03:39 AM
Drew Mazurek's Avatar
It's funny, with ICONs Avid went from silver to black. I wonder if the S6MKIIs will be silver!/!?!?
www.drewmazurek.com
Old 05-19-2016, 02:00 AM
tamasdragon tamasdragon is offline
For us the best solution so far is Clin, which is a window-glass-general purpose cleaner with some alcohol in it (we don not drink it thoug...). It removes all the fingerprints and keeps the S6 clean. Spray it on a micro-fibre cloth, never onto the surface.
my blog:Tamas Dragon
Old 05-19-2016, 01:13 PM
I'm glad someone updated this thread. I forgot about it.
I just ordered some Plexi-Clean from Amazon. I usually don't have too many problems with finger prints, but the dust kills me. This stuff is supposed to be anti-static and dust repelling.
Old 11-01-2017, 01:07 PM
laki laki is offline
Looks like Plexi Clean is not available in Australia and Amazon won’t ship it here. However, I can get the Novus 1. Is it safe to use?
Postman, are you still using it?
Old 12-12-2019, 02:19 PM
DHS DHS is offline
I use this stuff on my carbon fiber and plastics and my very expensive face shields which are plexi-glass and decided to spray a little on a polish cloth to clean a very dirty s6 surface. It made it look brand new again. Very little goes a long way.
Polish
Cleaning S6 Surface priorytools Avid S4/S6 8 04-22-2015 11:57 AM
Cleaning D-command surface deardaddy ICON & C|24 5 03-09-2010 07:51 AM
Cleaning the Surface of a Control 24 Buel Pace ICON & C|24 9 09-15-2008 01:35 PM
cleaning mud pioneerptw Tips & Tricks 19 01-07-2006 09:33 PM
Cleaning C24..... marcelloz ProControl, Control|24, Command|8 4 04-29-2001 01:28 PM
