Old 12-02-2014, 08:30 AM
BarryBianco BarryBianco is offline
Default Printed audio track timing drifts
This is my first post so please be patient. I'm using Protools 9.03 . When I record to an instrument track from my V-drum TD-6V module, the midi notes seem to be locked in time as they should be. When I send the midi note for the snare drum, for example, to an audio track and record them, the timing of the recorded audio track drifts around by as much as 2000 samples thus being badly out of time. The drift is not consistent. It will vary from being in sync to thousands of samples off to a few hundred samples off etc. from one snare hit to the next. I have tried delay compensation on and off, removing all plugins etc. to no avail. I'm open to any suggestions as I'm pulling what's left of my hair out.
The problem with learning from experience is that the answers always come before the questions
Old 12-05-2014, 12:59 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Printed audio track timing drifts
Hi, You should start here:
Help us Help You - READ THIS Before Posting!
and make sure to do ALL the Windows 7 Optimizations and Troubleshooting. Please post a SANDRA as described in the above link.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Problem with groove quantizing audio to the timing of a MIDI track gumplunger macOS 0 10-01-2014 12:24 PM
Printed Audio Not Playing kyluigi Windows 1 08-27-2014 12:59 PM
Printed Audio not playing sound. kyluigi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-27-2014 05:33 AM
Slave MPC 5000 to PT9.06 via Beat Clock - timing drifts when looping headsup macOS 4 02-11-2012 12:22 AM
New 11r track w/printed FX loop DAR Fritz Eleven Rack 8 02-17-2011 05:18 PM
