Old 08-05-2019, 06:47 AM
gdgross's Avatar
gdgross gdgross is offline
Default Elastic audio not committing
Hi all,
this has happened several times in the last month. have a tick based track which i've edited in elastic audio, I'd like to commit the changes, so I turn off EA and PT asks me if I want to commit or abandon the changes. I choose commit, but then I get a bunch of regions that look like the have no audio and produce no sound when played back (they look light blue like when PT can't find the audio file.)
Any ideas? I've already trashed my prefs.
Thanks
Geoff
www.merlotembargo.com
Old 08-05-2019, 09:16 AM
AlexLakis AlexLakis is offline
Default Re: ELastic audio not committing
Originally Posted by gdgross View Post
Hi all,
Thanks
I know this isn't a direct solution to your problem, but you could always bus the track out and bounce it to a new track in real-time (just to get it taken care of quickly).
Old 08-06-2019, 07:30 AM
Keep the Task Manager window open and see what's happening right after you hit commit.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 10-13-2019, 06:15 AM
Muzoid Muzoid is offline
Default Re: Elastic audio not committing
For a long time now, Elastic audio takes forever to commit. never used to do this!!! What is happening? I have PT Ultimate. After getting everything where I want it, I switch to X-form so the files have already been rendered (and that takes forever too!!!) but then hours to 'commit' a small # of tracks!!!
This is a complete session-killer. I definitely can't do this with a client present and can't do this if I need to keep working.. AVID, what is the deal? This is SO LAME!
Old 10-13-2019, 06:50 PM
#1-what happens if you put the track in Samples mode?
#2-the trick to X-Form(for me) is to separate the audio into manageable clips that fit the screen. That way, X-Form is only rendering a smaller clip instead of the entire track For me, X-form is all I ever use for timing edits(Monophonic and Polyphonic both introduce glitches in the audio). I do use Polyphonic for changing pitch
I've never had EA not commit, but you could do a Track Commit as that would(SHOULD) render a new audio clip with the EA moves "baked" in
Old 10-13-2019, 08:42 PM
cwsand's Avatar
cwsand cwsand is online now
Yes, and to add to that - don't process EA on tracks with large areas of blank audio. Cut them into separate clips and consolidate each individual clip first.
I also don't commit X-form on a bunch of tracks at the same time - PT sometimes freezes up when doing that.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Does this count as a bug? Elastic Audio not committing midnightrambler Pro Tools 12 1 02-04-2016 08:03 AM
Elastic Audio - Sounds Dreadful after committing alex s macOS 9 10-10-2013 01:39 PM
Have to manually clean up rendered files after committing elastic audio processing jdholman1 Pro Tools 9 1 05-30-2011 12:57 PM
Elastic Audio not committing to disk properly mixboy bob Pro Tools TDM Systems (Mac) 4 05-27-2009 12:32 PM
committing elastic audio in 7.4 is it fixed yet 2fly Pro Tools TDM Systems (Mac) 9 01-15-2008 05:08 PM
