Old 07-05-2019, 04:46 PM
bonzerboy bonzerboy is offline
Default IK Miroslav multi outputs
I have been watching some videos and I can change the individual instruments channels in the plug in to say out 3-4 etc try to make it go to aux track but still comes out main out put 1-2.. In the video i was watching it says you have stereo and multi to open but in pro tools it only has one option and that is stereo.
Wow am I groovy or what
Old 07-11-2019, 12:02 PM
Default Re: IK Miroslav multi outputs
Miroslav works in Sampletank right? Go to the mixer in Sampletank and assign each channel output to a different output pair. The first instrument defaults to channel pair 1 & 2 but you can assign that to any pair you want. It's output by default goes to the instrument track you have Sampletank inserted on.
Go back to the Sampletank mixer and assign each successive instrument to an output pair of your choosing. In PT create however many aux tracks you want to send the instrument's outputs to. Go to each of those aux tracks and click on the input field and select 'plugin' then Sampletank and then the channel pair in Sampletank you want to assign to said aux track. Repeat as necessary.
Same as most any other multi-timbral vi.
Jack
QAPLA!
Multi outputs for Logic or DP using PT HD Jim Morris Pro Tools 9 2 03-25-2011 02:16 PM
setting up multiple outputs w/ Miroslav philharmonik? Digitopian Virtual Instruments 3 05-07-2010 03:08 PM
Miroslav Philharmonik? garnoil Pro Tools TDM Systems (Mac) 22 03-15-2009 08:11 PM
Can I assign one track to multi outputs (digi002r) Ralph K 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-06-2004 06:54 PM
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 11:08 AM
