Old 09-24-2016, 03:53 PM
RickD16v RickD16v is offline
Default PT10 cannot see Eleven Rack in hardware or Playback Engine
See my signature for my config.
I've had a ton of issues trying to get Pro Tools 10 to open, the Eleven Rack Editor to see the ER, and trying to get PT10 to see the damn thing :
- The Eleven Rack Editor would not connect even though the ER Control Panel could, so i have switched from a USB 3 port to a USB 2 and removed the USB extension i was using, and this let the ER Editor load correctly, but i couldn't be sure...because the window would minimize automatically and i could never open it to see. To fix that, I had to remove all the files in the C / User / AppData / Roaming / Avid / Eleven folder.
- PT 10 opens fine (still warns me about NFTS names being too long) (i do not want to change the name of the System Reserved partition)...never had this problem on any software ever...
...BUT i cannot see the Eleven Rack in the Setup / Hardware or Playback Engine section. Just uninstalled and reinstalled PT10, still no change. Have also reinstalled the ER drivers and Editor.
What is strange is that it opens a window with the ER Editor when i load PT10, and it lets me select the ER when it asks me what sort of project i want to create. When i click in the editor, like 'tuner' for example, the ER reacts accordingly.
Thank you !
All the best,
RickD16v
Eleven Rack with latest everything.
Windows 7 Utimate x64
ProTools 10.3.10 (latest)
TC Electronic Impact Twin
A ton of problems.
Old 09-24-2016, 04:58 PM
Default Re: PT10 cannot see Eleven Rack in hardware or Playback Engine
You've run into one of those problems where a USB peripheral won't play nice with USB3 ports on a computer. The iLok2 does it and now apparently so does the 11R. Another one you found is that USB can be a bit finicky when it comes to cable length.
Couple of things to try: make sure any power saving measures for the USB ports are turned off in Windows Control Panel. Make sure your computer is set to never sleep. Third - try another USB cable. They can crap out without warning. Another thing and this is something I've run into on my system (Mac running OSX 10.9.5) is that on bootup my iMac doesn't see my 11R. I have to switch off the 11R and then restart it to get communications back.
Jack
QAPLA!
Eleven Rack Playback Engine? RoyceSlim Pro Tools 11 9 04-06-2015 05:20 AM
PT10 "sees" Eleven Rack as playback engine only (no editor window,embedded rigs,etc) locust_tree Eleven Rack 4 12-08-2014 03:16 PM
Pt10 and eleven rack no playback benhoulihan Pro Tools 10 4 02-23-2013 12:23 PM
PT9 can't find Eleven Rack as playback engine! vinceh Eleven Rack 2 01-18-2011 06:51 PM
PT-HD9 vs. PT-HD9 using Eleven Rack's Playback Engine acmost Pro Tools 9 0 11-14-2010 08:23 AM
