shutting off input monitoring
Is there a way to stop all input audio from coming through PT when recording?
I'm monitoring through the M-audio mixer application, so I don't need the audio to also be running through ProTools. So far what I end up doing is using input only monitoring with the record and play faders unlinked, and then every time I record enable a new track, I have to turn down the record fader for that track. Sometimes I forget, and then everything sounds like Elvis. I'd like something simpler than having to turn down every record fader... I'm still on a single processor machine, so I can't have the buffer set low enough to make latency insignificant. -thanks |
Re: shutting off input monitoring
Just mute the track you're recording.
Input FX monitoring | abt | Windows | 0 | 10-12-2013 04:57 PM |
Input monitoring | Sunshy | Pro Tools 11 | 3 | 08-16-2013 10:00 PM |
Input monitoring | rmiller335 | Windows | 5 | 06-01-2012 08:36 PM |
Auto input/input only monitoring failing in PTLE 8.0.4 | miketeachesclass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-11-2012 08:48 AM |
Auto Input monitoring / Input only monitoring - Alt+K | AdamPT8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-09-2010 10:50 AM |
