Re: New to PT 12.8.3
BTW Pro Tools 2019.5 is such a fantastic release and improves CPU related errors and overall scalability so much that I would not be messing with Pro Tools 12.
Eric Bolvin Add horns to your project!! http://www.bolvinmusic.com/horns-r-us.html 408.236.2009 |
Eb
disable or uninstall Avast. You should not have any AV software running when using a DAW. Even better just don’t install it on Windows, user basic care is much better protection.
Follow the directions for running Sandra in the troubleshooting section on DUC. Sandra not being able to run can be (usually is?) an indication your system has problems If you do a Windows 10 install do it on a spare drive/partition and just install Pro Tools, latest ILM and your interface drivers and chevknit all works perfectly, then reinstall plugins etc. Windows often does well with that smack on the head of a full clean install. |
So things are much better. Not sure which procedure helped, but things are much better. However there is still the occasional pause. So I did the Sandra report. Not sure where I'm supposed to put it, but Here it is:
SiSoftware Sandra ID Host Name : Eric-Win7DT Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS P6T Serial Number : MSPC8CB******** BIOS : AMI (OEM) 0202 12/04/2008 Total Memory : 12GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (4C 8T 2.81GHz/3GHz, 2.14GHz IMC, 4x 256kB L2, 8MB L3) Chipset Memory Controller : ASUS X58 I/O Hub 2x 2.41GHz (4.82GHz) Memory Controller : Intel Core Desktop (Bloomfield) UnCore 2x 2.41GHz (4.82GHz), 3x 4GB DIMM DDR3 1.07GHz 192-bit Memory Module(s) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Video System Monitor/Panel : Samsung SyncMaster (1920x1080, 24.0") Monitor/Panel : ACI ASUS VS247 (1920x1080, 23.4") Video Adapter : NVIDIA GeForce GTX 550 Ti (4CU 192SP SM5.0 1.9GHz/1.8GHz 5% OC, 1GB, PCIe 2.0 x16) Video Adapter : NVIDIA GeForce GTX 550 Ti (4CU 192SP SM5.0 1.9GHz/1.8GHz 5% OC, 1GB, PCIe 2.0 x16) Graphics Processor OpenCL : NVIDIA GeForce GTX 550 Ti (192SP 4C 1.9GHz/1.8GHz 5% OC, 1GB) D3D 11 : NVIDIA GeForce GTX 550 Ti (192SP 4C 1.9GHz/1.8GHz 5% OC, 1GB) OpenGL : GeForce GTX 550 Ti/PCIe/SSE2 (1GB) OpenGL : GeForce GTX 550 Ti/PCIe/SSE2 (1GB) Storage Devices WDC WD20EFRX-68EUZN0 (2TB, SATA300/600, 3.5", 5400rpm) : 2TB (D:) (F:) (G:) (H:) WDC WD20EFRX-68EUZN0 (2TB, SATA300/600, 3.5", 5400rpm) : 2TB (C:) (J:) Seagate ST1000DM003-1ER162 (1TB, SATA300/600, 3.5", 7200rpm) : 932GB (E:) DVDRW IDE 16X (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (I:) ROXIO DVD-ROM EMULATOR (SCSI, SCSI-2, DVD-R, CD-R, 4kB Cache) : N/A (L:) Logical Storage Devices Videos (D:) : 307GB (NTFS, 4kB) @ WDC WD20EFRX-68EUZN0 (2TB, SATA300/600, 3.5", 5400rpm) WINDOWS7 (C:) : 932GB (NTFS, 4kB) @ WDC WD20EFRX-68EUZN0 (2TB, SATA300/600, 3.5", 5400rpm) Samples (E:) : 932GB (NTFS, 4kB) @ Seagate ST1000DM003-1ER162 (1TB, SATA300/600, 3.5", 7200rpm) Music (F:) : 849GB (NTFS, 4kB) @ WDC WD20EFRX-68EUZN0 (2TB, SATA300/600, 3.5", 5400rpm) OthFiles (G:) : 400GB (NTFS, 4kB) @ WDC WD20EFRX-68EUZN0 (2TB, SATA300/600, 3.5", 5400rpm) Masters (H:) : 306GB (NTFS, 4kB) @ WDC WD20EFRX-68EUZN0 (2TB, SATA300/600, 3.5", 5400rpm) Sessions (J:) : 931GB (NTFS, 4kB) @ WDC WD20EFRX-68EUZN0 (2TB, SATA300/600, 3.5", 5400rpm) Optical Drive (I:) : N/A @ DVDRW IDE 16X (ATA66, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (L:) : N/A @ ROXIO DVD-ROM EMULATOR (SCSI, SCSI-2, DVD-R, CD-R, 4kB Cache) Peripherals LPC Hub Controller #1 : ASUS LPC Interface Controller Audio Device : EVGA GF116 High Definition Audio Controller Audio Codec : nVidia 0015 Audio Codec : nVidia 0015 Audio Codec : nVidia 0015 Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller #1 : ASUS USB UHCI Controller #4 USB Controller #2 : ASUS USB UHCI Controller #5 USB Controller #3 : ASUS USB UHCI Controller #6 USB Controller #4 : ASUS USB EHCI Controller #2 USB Controller #5 : ASUS USB UHCI Controller #1 USB Controller #6 : ASUS USB UHCI Controller #2 USB Controller #7 : ASUS USB UHCI Controller #3 USB Controller #8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller #1 : ASUS VT6315 Series Firewire Controller SMBus/i2c Controller #1 : Intel ICH SMBus Printers and Faxes Printer : CutePDF Writer (4000x4000, Colour) Printer : Canon iP2700 series (USB, Colour) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.1.7601 (Service Pack 1) Platform Compliance : x64 Performance Enhancing Tips Warning 2513 : TPM not detected. Some security features are unavailable. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
#16
All those 5400 rpm drives are your problem. You really should have all 7200 rpm drives or even ssd's. 12 gig ram isn't helping things either. PT would really like to see a minimum of 16 gig. Fix those and your pause issues and other gremlins you're having should go away.
#17
Thank you. I am looking into getting things upgraded.
Meanwhile things are working however I seem to be "stuck" at 256 Playback Engine. There are no other options, just 256. Also when I create a session, 48K is not available to me. Any suggestions are appreciated. Eb
#18
