  #21
Old 05-30-2019, 03:40 AM
tetonica's Avatar
tetonica tetonica is offline
Default Re: To HEAT or not to HEAT?
Originally Posted by midnightrambler View Post
Hmm. It makes everything louder
Yes - is louder but also different - I asked my wife to listen without explaining what it was (HEAT, tube / tape saturation) and she preferred the same tracks with HEAT - I asked her "is it because is louder?" and she said "no, it simply sounds better" (she would not like the price $$ but that's for another day)
  #22
Old 05-30-2019, 04:02 AM
midnightrambler midnightrambler is online now
Not scientific enough. Print 2 mixes, get them level matched (maybe use a LUFS meter?), then get her to listen. Nearly every "lay" person will prefer a slightly louder signal and say it sounds "better", even if they can't detect that's it's 1dB or so (unless obvious clipping occurs). If you don't believe me just run off exactly the same mix but make one 1/1.5dB louder. She will definitely say she louder one sounds "better", even though it's exactly the same mix.
If you're using the "tone" knob then that will obviously make the mix slightly brighter or darker, and again, most people will say they prefer a slightly brighter signal...unless it's so bright it's starting to take your scalp off.
  #23
Old 05-30-2019, 04:21 AM
tetonica's Avatar
Ah - I actually did measure with Audio Suite > Other > Pro Limiter Loudness Analyzer and the HEAT mix got to 14 LUFS while the non-HEAT was originally 16 LUFS
Then I re-worked the HEAT mix to match the original mix at 16 LUFS (just tweaking "Pro Limiter" at the end of master bus). Then I listened to both mixes and they sounds very similar, except the HEAT mix has a little something else that is pleasant
In the end I'm just testing it before I make a decision to upgrade my vanilla Pro Tools (permanent license) to Pro Tools Ultimate + HEAT. I know there are plugins that do something similar (tube / tape saturation) but none is integrated in the mixer like HEAT (which i think is elegant).
Besides the sound, I also I like the blinking yellow lights in the mixer tracks when HEAT is working, reminds me of vintage tube amps
  #24
Old 05-30-2019, 04:39 AM
Great - if you like it, go for it
  #25
Old 06-12-2019, 08:09 PM
685 685 is offline
I was wondering what settings everyone uses?
My mix template is set to:
Audio Tracks: PRE
Drive: 1 O'clock
Tone: 11 O'clock (sometimes 2 O'clock)
  #26
Old 06-13-2019, 12:56 AM
moshuajusic moshuajusic is offline
I bet most would've been happier with HEAT in PT vanilla than the dozen random extras they threw in over the last few years.
  #27
Old 06-13-2019, 02:00 AM
JFreak's Avatar
JFreak JFreak is online now
All of us would be happiest once PT goes full circle and returns to one unified (1st excluded) software. I'm not holding my breath though...
Janne
  #28
Old 06-14-2019, 01:32 PM
the.engineer the.engineer is offline
Audio Tracks: PRE
Drive: 1 O'clock
I have drive set to -2 (10 o clock) and tone set to +1 (1 o clock) I love it!
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon R9 280X 3072 MB | 256GB Samsung SM951 SSD Blade (PCIe) System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Mojave 10.14.5 | Pro Tools Ultimate 2019.5 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
James Welch
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #29
Old 06-14-2019, 02:19 PM
TOM@METRO's Avatar
When I use HEAT, I often use that same setting.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #30
Old 06-14-2019, 04:35 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Downunder we have DeepHEAT doesn’t do much for PT but great for muscle pain
I would happily give back all the free stuff.... which I don’t really use to have HEAT in PT vanilla
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
HEAT Mark Dann Buy & Sell 3 12-11-2014 07:42 PM
Heat $175. Mark Dann Buy & Sell 5 11-19-2014 07:15 AM
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
re heat on 10 2224 macOS 9 08-12-2012 05:11 PM
Heat? or Something Like it? Numi Pro Tools 9 24 06-11-2011 06:13 PM
