Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 05-10-2019, 12:50 PM
MarcOFB MarcOFB is offline
Default S5 & Pro Tools 2019.5
For those it may interest i tried out Mojave and PT2019.5 with the S5 today, and everything seems to be running okay, there was even a VCA issue in 2018.12 that is now working.
No smart switches or transport however as no appset is made for it as far as i know.
Old 05-11-2019, 10:02 AM
EddieJones's Avatar
Default Re: S5 & Pro Tools 2019.5
rename the old appset to have 19 in the name instead of 12 or 18
Old 05-11-2019, 10:23 AM
I tried that, but i didnt reboot the sc264 afterwards, which may be why. Thank you Eddie always hugely appreciated!
Old 05-12-2019, 07:48 AM
Ulf Ulf is offline
I have lost my transport control from my S5 system after installing Pro Tools 2019.5! Any quick fixes???
Best regards Ulf
Mac Pro 2x3,46 GHz 6-Core OS 10.13.6
System 5 SC264D, CM408x3, CM402, CM401
AM713, MA703, ML530, MC524, FC726
ProTools Ultimate 2019.5, Avid MTRX
Old 05-12-2019, 08:23 AM
Ulf you have to make a new appset named Pro Tools19.xml that will give you back transport and smart switches.
EddieJones's Avatar
I presume you mean EUCON Transport Control ? If so you need to rename the Appset putting in 19 (instead of 12 or 18)
Old 05-13-2019, 08:15 AM
I had this peobem with pt2018 aswell ad 2019. I renamed the appset but still have no transport or smart switches. Is there a certain way to do this? Does one rename then reboot, or remove the appset then rename it and put it back and then reboot?
Do you do it with pro tools connected?
I remember i fixed it last time but i cannot for the life of me remember the order i did it in.
Pro Tools 2019 ! abomeerza Pro Tools 2019 1374 05-14-2019 07:13 AM
