Old 03-22-2019, 07:35 AM
hnbike hnbike is offline
Default 9073 error
I keep getting the 9073 error message everytime I play back or try to record on a session in pro tools le 8.04, 002 black lion modded rack, windows xp pro. It started happening after a lot of midi editing using toontrack easy keys and easy drummer. I have trashed prefs, deleted used regions, consolidated all tracks and saved as in, deleted the instrument tracks with easy keys/easy drummer. H/W buffer 512, cpu - 85%, dae playback level 2, normal cache size. Will stop with only 56% cpu usage. I am only using a Massey compressor on 4 tracks and Sans Amp on the bass track - 11 track session. I can play back much larger sessions with lots of plug-ins with no problem. Sandra report below. Help! F drive is 7200 and is nnot full.
<<< Computer Overview >>>
< System >
Host Name: TRS-F0777D538F2
User: TRS
Workgroup: WORKGROUP
< Processor >
Model: Intel(R) Core(TM)2 Quad CPU Q6600 @
2.40GHz
Speed: 2.40GHz
Cores per Processor: 4 Unit(s)
Threads per Core: 1 Unit(s)
Type: Quad-Core
Internal Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64
byte line size
L2 On-board Cache: 2x 4MB, ECC, Synchronous, ATC, 16-way, 64
byte line size, 2 threads sharing
< System >
Mainboard: Intel Corporation DP35DP
Bus(es): PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support: No
Multi-Processor Advanced PIC (:Yes
System BIOS: Intel Corp. DPP3510J.86A.0413.2008.0306.2218
Total Memory: 3.25GB DIMM DDR2
< Chipset >
Model: Intel P35/G33/G31 Processor to I/O Controller
Front Side Bus Speed: 4x 267MHz (1.07GHz)
Total Memory: 4GB DIMM DDR2
Memory Bus Speed: 2x 401MHz (802MHz)
< Memory Module(s) >
Memory Module: Micron 16HTF25664AY-800E1 2GB DIMM DDR2 PC2-
6400U DDR2-800 (5.0-6-6-18 3-24-6-4)
< Video System >
Adapter: NVIDIA GeForce 8400 GS (256MB DDR2, 425MHz/
986MHz/2x399MHz, PCIe 1.00 x16, PS3.0, VS3.0)
< Graphics Processor >
Adapter: GeForce 8400 GS (1.01, 256MB, 918MHz)
< Storage Devices >
ST3250310AS 250GB (SATA300, 3.:233GB (C:)
ST3250310AS 250GB (SATA300, 3.:233GB (F:)
Lexar USB Flash Drive 16GB (:15GB (E:)
LITE-ON DVDRW LH-20A1S (SATA15:N/A (D:)
< Logical Storage Devices >
Hard Disk (C:): 233GB (NTFS) @ ST3250310AS 250GB (SATA300,
3.5", NCQ, 8MB Cache)
Local Disk (F:): 233GB (NTFS) @ ST3250310AS 250GB (SATA300,
CD-ROM/DVD (D:): N/A @ LITE-ON DVDRW LH-20A1S (SATA150, DVD+-
RW, CD-RW, 2MB Cache)
Removable Drive (E:): 15GB (FAT32) @ Lexar USB Flash Drive 16GB
(USB)
< Peripherals >
LPC Hub Controller 1: Intel (ICH9) LPC Interface Controller
Audio Device: Intel (ICH9) HD Audio Controller
Serial Port(s): 2
Disk Controller: Intel (ICH9) 4 port Serial ATA Storage
Controller 1
Disk Controller: Intel (ICH9) 2 port Serial ATA Storage
Controller 2
Disk Controller: Marvell 6101 SATA2 Controller
USB Controller 1: Intel (ICH9) USB Universal Host Controller
USB Controller 2: Intel (ICH9) USB Universal Host Controller
USB Controller 3: Intel (ICH9) USB Universal Host Controller
USB Controller 4: Intel (ICH9) USB2 Enhanced Host Controller
USB Controller 5: Intel (ICH9) USB Universal Host Controller
USB Controller 6: Intel (ICH9) USB Universal Host Controller
USB Controller 7: Intel (ICH9) USB Universal Host Controller
USB Controller 8: Intel (ICH9) USB2 Enhanced Host Controller
FireWire/1394 Controller 1: Intel TSB43AB22 1394a-2000 OHCI PHY/Link-
Layer Controller
System SMBus Controller 1: Intel 801xx/63xx SMBus
< Printers and Faxes >
Printer: Microsoft Office Document Image Writer Driver
(300x300, Colour)
< Network Services >
< Power Management >
Mains (AC) Line Status: On-Line
< Operating System(s) >
Windows System: Microsoft Windows XP Professional 5.01.2600
(Service Pack 3)
Platform Compliance: x86
< Performance Tips >
Tip 2546: Large memory modules should be ECC/Parity.
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
<<< Physical Disks >>>
Old 03-22-2019, 12:21 PM
Default Re: 9073 error
Edit - using pt le 8.0.5
DAE 9073 Error (Disk too slow) Error peytontodd Windows 8 08-21-2014 01:32 PM
Error DAE cant get audio from drives fast enough -9073 error on BIG MIX SESSION dairyman3833 Pro Tools 10 4 06-26-2014 08:35 PM
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 Karma180 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-05-2011 07:46 PM
adat loopback error#4 and error 9073 uri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-22-2003 11:19 AM
DAE Error -9073 onno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-25-2000 12:06 AM
