Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-07-2018, 08:56 AM
graveleye's Avatar
graveleye graveleye is offline
Default Weird MOTU MK3 Hybrid problem
Had a weird thing happen last night. I booted up my DAW as usual after months of flawless performance. Since I have a MOTU 896, I launch Cuemix first, as is the ritual. Only nothing happened. Tried again. Nothing happened. Reboot, nothing happened.
I went into panic mode. Shut everything down, unplugged the MOTU power cord and firewire cable, as well as the lightpipe to my other preamp. Plug it all back in. Reboot.
OK it found it and Cuemix launched, PT launched and I'm happy.
Then, I go to record and the latency is insane. What the hell?
Of course, I don't have to fool with this stuff much, so it took me forever to figure out that for some reason the bitrate buffer had set itself to 512. WHY? I adjust it back to a decent buffer, and reset the track monitoring so I can hear when tracks are record enabled.
For some reason, all those settings just went wonky all on their own, after years of perfect operation.
1ST off, why did this happen in the first place? Is my unit going bad or maybe a faulty firewire cable?
Was it because I unplugged everything?
I'm so confused about it, but did get it back to working last night.
Only now, I'm filled with anxiety that I'm going to get home and it's going to pull the stunt again. Hopefully not, but we'll see.
GIGABYTE X58A-UD3R, INTEL CORE i7 960, NVIDIA GEFORCE 8400GS, WIN 7, MOTU 896mk3 HYBRID, PT 10.3.2
Old 01-15-2019, 08:46 PM
drumdude21 drumdude21 is offline
Default Re: Weird MOTU MK3 Hybrid problem
I had something similar happen, though it wasn't the buffer settings, rather the sampling rate. I use a MOTU 8pre in conjunction with a 828mk3. Upon firing them up one day, the 8pre had switched from 44.1khz to 48khz.
My only guess is something caused the interface to revert to its default buffer settings (or in my case sample rate).
Doesn't the 896 have USB on the back? I'd ditch firewire personally.
MOTU 828x vs 828mk3 Hybrid mikefont Third Party Interfaces 1 04-09-2015 10:07 PM
Use Behringer x32 compact and Motu Hybrid 896mk3 with Protools at the same time albikat2014 FireWire & USB Audio Interfaces (Win) 2 02-08-2015 07:51 PM
MOTU 828mk3 Hybrid - Lowest Buffer Size txshonk Windows 3 07-15-2012 08:11 AM
Hybrid looks weird .. Jperkins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-09-2008 07:34 AM
Digi001, MOTU MidiExpress, Logic 7 old/new hybrid Luna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-29-2005 10:12 AM
