iCloud PT2018 problem.
I downloaded PT 2018.7 last night on to my MBP 2012 and its working fine. My problem which I can't find an answer to is this, I downloaded PT to my iCloud Drive it seems. I shouldn't have done that but it happened. Does anyone know how to move that Protools folder full of stuff off the iCloud Drive and into my Applications folder locally, where I believe it should live, no?
www.kfaudio.ca |
Re: iCloud PT2018 problem.
from a closer examination, it seems the folder called ProTools on my iCloud Drive is all presets, grooves etc etc. I assume the actual program got loaded locally but all the 'document' type files got put to the iCloud......ok, I think I should be able to just move it all to the local app folder....
www.kfaudio.ca |
That Pro Tools folder you're referring to should be in your Documents folder, I have no idea why it's on your icloud drive . In any case, you have access to your iCloud drive from the Finder so just copy it to your local drive I guess?
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4 Arturia Keylab 88 • Presonus Faderport 8 • MOTU 896 • iPad Air 2 w/ PT Control NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc |
everything from my documents folder appears to be in that icloud drive, so i guess i gotta turn it off. eats up a lot of storage.......thats why it happened......now to undo it......
www.kfaudio.ca |
yup, all working now..my icloud drive was storing everything off the dcuments and desktop folders, which happens automatically , when u checked those boxes in system prefs.....forgot all about that.....i guess thats cool for certain scenarios....not me...
www.kfaudio.ca |
Files under iCloud a bad idea? | rcook349 | macOS | 6 | 11-27-2017 10:10 AM |
PT First and iCloud | Elbergo | Pro Tools | Intro Discussion | 4 | 05-03-2017 06:06 PM |
iCloud has eaten my projects!? | Daniel Barnes | Pro Tools | Intro Discussion | 1 | 02-08-2016 01:51 PM |
iCloud... ANY Problems? | Shifted Music | Pro Tools 10 | 4 | 03-02-2014 09:52 PM |
New Mac PT 10 and related problems (iCloud, App Store, etc) | allen_gibberish | Pro Tools 10 | 18 | 03-05-2012 07:25 AM |
