Old 06-05-2016, 02:31 PM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
Default Avid HD OMNI missing firmware - missing audio interface
I just tried to use my hardware, after some weird noises come from all the outputs. I tried the digitest and it come up with missing firmware! (HD OMNI) info.
I then reset using the HD omni setup with no luck.
Tried again the digitest and this time I tried to update firmware, as we all know there's a bug that the spinning wheel appear and it seems as stopped, I didn't quit digitest and after a couple of minutes the HD Omni reboot and again state that it have the version 2.10. I then shutdown everything (normal workflow after you use digitest). And guess what.
I tried to open Pro tools HD 12.5 and the missing audio interface appear. I tried both Digi ports of the HD Native TB, no luck.
I need some help, to see if this is a broken unit.
update:
I've got sometimes the AAE 1125 and the DSI error 1125.
I've tried other minidigitlinks cables.
Regards,
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
Old 06-06-2016, 06:03 AM
jbrown7282 jbrown7282 is offline
Default Re: Avid HD OMNI missing firmware - missing audio interface
I have never seen that behavior with OMNI before.... Let me check on a few things for you before I refer you to Avid Support...
Jay
Litehousemuzik
Audio Mixing Services
Old 06-06-2016, 06:06 AM
Thanks jbrown7282
Ive tried in another Mac too, changed the thunderbolt cable.
Today Ive bring it back to my work where we have at least 6 HD omni and try to see if it works. Ill update with that test too.
Marco Bernardo
PT HD 10/11 HDN Thunderbolt | HD OMNI | Frontier Alpha Track | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Everpack
Marco Bernardo
Old 06-07-2016, 03:20 PM
Just another update:
I've tried connected to 4 different Pro tools workstations with no luck. When Pro tools is opening asks me to connect an audio interface because is not detecting any.
Marco Bernardo
Old 06-10-2016, 07:06 AM
ronnievanoverveld ronnievanoverveld is offline
I'm having the same problem, but with my HD IO digital. In Digitest it shows that it has no firmware and when I update it to version 5.5 it says it is successful, but when I restart Digitest I get the same problem. The leds constantly flickering.
Hope someone can help!
Ronnie van Overveld - Sounddesigner - The Netherlands
Mac Pro Trashcan OSX Mojave, ProTools 2021.3.1 Ultimate, Focusrite Red4pre, Avid S3, Avid PT DOCK, AJA IO XT
Old 06-13-2016, 09:40 AM
I tried everything I need some help to see if I can do anything more before send it back. Im kind of fuc??"#"%" up because I have some work to finish... arghhh...
Any ideas? Thanks in advance.
Link to Screenshots of all the errors that occur
Regards,
Marco Bernardo
Old 06-14-2016, 05:46 PM
Added a video with the error when it's on
I'm in middle of some works to finish.
I sent a email to musicstore.de where it was bought, hope they help me out fast.
Is still in warranty (I hope).
Marco Bernardo
Old 06-14-2016, 06:15 PM
Buccanears's Avatar
Buccanears Buccanears is offline
Hi Marco, I don't know if this helps, but maybe try Digitest from 12.4?
http://duc.avid.com/showthread.php?t=380239
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 06-14-2016, 06:16 PM
Thanks, I already tried it... no luck.
Marco Bernardo
Old 06-19-2016, 11:00 PM
Hi Marco,
Have you made any progress with your Omni? Mine is still working good, only my HD IO is having the "Missing Firmware" problem.
My dealer says it needs to be repaired with Avid, but as it is still recognized by Digicheck, I 'd think it must be a software problem. That shouldn't be that difficult to repair I think?
I hope Avid can chime in here so maybe we can make it to work.
Omni and monitoring - am I missing something? Erik Olsson Post - Surround - Video 10 07-01-2012 11:55 AM
OMNI and monitoring - am I missing something? Erik Olsson Pro Tools 10 0 06-19-2012 12:43 PM
Missing fade files, missing audio in resaved sesssions drygruo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-14-2010 04:56 PM
missing audio files are actually not missing tomcat Pro Tools TDM Systems (Mac) 3 12-24-2006 02:25 PM
firmware missing please help jonpaulmusic Pro Tools TDM Systems (Mac) 0 09-28-2006 05:06 PM
