Old 06-04-2019, 03:18 AM
Bulley Bulley is offline
Default Can't close Pro Tools
Whenever I try to close down Pro Tools it restarts automatically. Tried trashing prefs but still does it.
Latest version but did it on the previous one as well.
Any ideas?
Old 06-04-2019, 07:05 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Can't close Pro Tools
Is there any Windows error message? Sometimes when an app crashes, Windows will try and restart it.
Will K
System Details
Old 06-04-2019, 07:13 AM
No error message. If I close Pro Tools as soon as it reboots it's fine, if I leave it a minute or so then it will try to restart if I close it.
Old 07-16-2019, 05:43 AM
theposterkid theposterkid is offline
I am experiencing the same issues. I close a session, and quit Pro Tools, and it immediately starts again. I have a MCU Pro and two MCU XT Pro’s connected and a Motu 16A connected via usb.
I get the same issue on 2018.12, 2019.5, and 2019.6, I have tried them all.
This is a new computer build. It only starts to happen after Windows Updates occur. In an attempt to fix this issue I did a fresh Windows install. I spent the afternoon installing plugins and driver for the Motu, and PT. The problem did not occur. I created a system restore point before the Windows updates. Windows updated, then the problem came back. I restored from my restore point, but the problem persists.
No Windows error messages.
Windows 10 Home build 1809. OS build 17763.107
Intel Core i5-9600k
32gb ram
Last edited by theposterkid; 07-16-2019 at 06:22 AM. Reason: Providing more specifics
Old 07-16-2019, 11:54 AM
Changing the playback engine to Windows Audio Device with my display monitor selected as the output has no bearing on the problem. Pro Tools still reopens itself. However, I have found that when I unplug my MOTU 16A usb cable and restart PT, it restarts itself LESS often. It almost makes it seem like the problem is gone. But after a few times of successfully closing and re-opening Pro Tools, without it opening itself back up, it eventually did it again even without the MOTU 16A connected.
Windows 10 Home
Pro Tools 2018.12
Motu 16A
Mackie MCU Pro
Old 08-11-2019, 11:00 AM
hbhunt hbhunt is offline
I am having the same issue with Pro tools restarting itself. Never had this problem until I installed 2019.6 on my Windows 10 machine. When I startup and then open Pro Tools to work the first time I close it down it will restart itself. After that it works as it should.
I am using an Apollo interface. No error messages at all.
Old 08-12-2019, 10:13 AM
Yep, I'm still having this problem, if anything it's worse, it used to be that if I closed it as soon as it opened I'd be okay but now it restarts itself everytime.
Old 08-13-2019, 11:04 AM
Jacbert Jacbert is offline
Me too!! Started with 2018 something.. I suspect Windows 10...
Very annoying and frustrating.
Jacbert..
Old 09-10-2019, 07:23 AM
...it's still doing it. Very frustrating.
Windows 10 Home
Pro Tools 2018.12
Motu 16A
Mackie MCU Pro
Old 09-11-2019, 10:16 AM
mandal mandal is offline
Midi-related?
Avid OMNI PCIe
Pro Tools Ultimate 2020.5
Avid HEAT
Dell 43" 4K LED P4317Q
CPU: Intel Core i9-10980XE
Motherboard: Gigabyte X299X AORUS MASTER E-ATX
Cooler: Be quiet! Dark Rock PRO 4
RAM: 64 GB Crucial Ballistix Sport LT DDR4
Screen card: MSI GeForce GTX 1660 VENTUS XS OC
Cabinet: Fractal Design Define 7 XL Black
Disk1: Samsung 970 PRO 1TB M.2 SSD
Disk2: Samsung 840 PRO SSD
Disk3: Samsung 860 EVO SSD
Power: Corsair RM750x, 750W PSU
Microsoft Windows 10 Home 64-bit OEM DVD
12.7 .0.676 Install Update Prompt Endless Loop AVIDIVA Pro Tools 12 2 12-22-2016 01:26 AM
Activating my PT9 to PT10-PT11 upgrade is an endless loop? mike_mccue Windows 1 06-23-2013 03:45 PM
Core audio - sound stuck in endless loop lpbaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-23-2010 08:03 AM
Bounce to Disk creates endless loop boneboy Pro Tools TDM Systems (Mac) 2 08-13-2006 08:05 PM
Need Help with endless loop Mark Manela Pro Tools TDM Systems (Mac) 1 05-28-2002 04:27 PM
