Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 09-19-2019, 04:31 AM
senghor senghor is offline
Default problem with instrument track
I have a problem with PT's instrument track. When I records ie. bass or drums (plugin) on the track - first it plays back normally. Then sometimes I have no sound on the track, but after a few bars the track starts to play normally. Bizarre.
This happens quite often.
I am on WIN10 and PT 2019.6.
What is the problem?
Thanks for your answers!
Win10 Home Premium, SP1
Intel i7-4770K @3,5GHz, RAM 16GB
GA-Z87N-WIFI (rev. 1 and 2)
Scarlett 6i6 and pre-amps, Pro Tools 2019.10
Old 09-19-2019, 04:50 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: problem with instrument track
First I heard of this.
More common problem with VI tracks is you don't have the VI settings visible on your mix window and after closing and reopening session the settings have not been restored properly. In which case you just re-set it from the dropdowns.
But that it doesn't work at first and then starts working beats me.
Janne
Old 09-19-2019, 09:29 AM
Originally Posted by senghor View Post
Just to be clear, is the bass track is a VI as well?
Are there other tracks in the session? Do they keep playing back OK?
"Sometimes" but once when this happens does it keep doing it in the same place in the session? If so you may have unintended automation on the track, e.g. volume automation.
One suspects may be accidental keyboard shortcuts being pressed (I've seen a flakey keyboard do stuff almost by itself)
Do you see the meter moving on that track when you cannot hear its output?
What exact VIs are you using? You can also try just swapping the VI for MiniGrand and seeing if that shows a similar problem.
Instrument Track Input problem typhy macOS 1 10-04-2011 09:12 AM
Problem Converting Instrument Track to Audio Track Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-02-2009 09:11 PM
Instrument Track problem TheWillies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-14-2009 10:31 AM
Instrument track problem stanjank MIDI 4 11-13-2008 10:57 AM
INSTRUMENT track PROBLEM Friend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-07-2007 12:39 PM
