Old 01-07-2019, 11:32 AM
amiller amiller is offline
Default 911! Anyone know the power supply for D Command?
My power supply blew up this morning. Anyone know the kind used for the D Command by chance?
PT 12.7 HDX 2/Mac OS 10.10.5
2012 Mac Pro 3.46GHZ/64GB RAM
Old 01-07-2019, 02:17 PM
mixboy bob mixboy bob is offline
Default Re: 911! Anyone know the power supply for D Command?
Here you go!!
I have replaced 2 of mine with this. There are 3 supplies in each unit, so make sure it's the right one!
https://power.sager.com/snp-z10b-3979628.html
Good luck!
Rob Burrell
aka mixboy
http://www.robburrell.com
PTHD Ultimate/Eucon (latest betas) / Mac Studio Ultra 128GB RAM / Aja T-Tap / Sonnet M.2 4x4 PCIe 8TB / Focusrite 16Line / MTRX Studio / UAD Octo / 32 channel S1 & Dock (5) 2019 Fire HD 10 / Dolby Atmos 9.1.4 /Mastering Suite / 13.0 Sony 360RA
Old 01-08-2019, 12:16 PM
Actually found the same thing, thanks! Turns out it was a bad chip. Overnighted a new one and BAM, back up and running as of just now!
Old 01-09-2019, 03:19 AM
Will Russell's Avatar
Will Russell Will Russell is offline
A bad chip? Where?
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 01-24-2019, 12:39 AM
Jeezer Jeezer is offline
Always check capacitors on PSUs (virtually 'free' if you can solder) before buying whole new PSUs.
Easy to check, easy to change and in 8/10 cases it'll be a cap that's gone bad or is going bad.
Old 12-01-2019, 01:14 PM
elonn elonn is offline
Is someone know how to open the dcommand to access to the power supply module. Is there a video somewhere in the web (I didn’t find it ).
Thanks to all member of that group.
Eric Lonni
Re recording mixer with a dcommand with the same problem as yours.
Old 12-02-2019, 09:17 AM
crizdee's Avatar
crizdee crizdee is offline
Eric Lonni
Take the right hand side panel and metal side panel off, about 16-20 small screws holding the metal panel on.
Then undo the 8 top allen bolts that hold the monitor and dynamics section in and just pull these sections out taking care of the connecting cables/ unplug them. and there you will see the 3 power supplies. Logic board power supply on the left. LED power supply in the middle and the faders power supply on the right.
Inspect capacitors for bulging on the top. caps have a cross carved on the tops to aid when they expand so you can see where they lift and bulge when they fail.
If you view one of my facebook posts here you can see the power supplies and a blown cap on the logic board...
https://www.facebook.com/photo.php?f...type=3&theater
Here's the whole post with info about the caps ive bought...
https://www.facebook.com/photo.php?f...&theater&ifg=1
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-02-2019, 09:22 PM
Syncrecy Syncrecy is offline
Hello all,
I need little...
The power supply for my C|24 has left the building. Does anyone happen to know the part number that Sager would recognize?
The unit is from Skynet #850-z300-D
There is a clicking sound coming from the unit, it currently being repaired but not feeling good without a backup or contingency plan.
Thanks
Lou
Old 12-05-2019, 10:33 AM
Quick Update:
Power Sager doesn't carrie this PSU () any longer... I'm hope to get some help / info here.
The repair guy just informed me that he could fit it ...
I would appreciate any help I can get
Thanks in advance,
Lou
Old 12-06-2019, 06:55 AM
puffin puffin is offline
Jimmy English
Allpro Electronics
606 Fesslers LN # 103
Nashville, TN 37210
http://www.allproelectronics.com/
[email protected]
PH: 615-310-2379
Brian Power, CAS
www.thehideoutstudios.com
2 Mixing stages in Nova Scotia!
Home to the Trailer Park Boys, 22 Minutes and Mr D as well as many more. Need proper ADR in Nova Scotia? I'm the call to make.
Command 8 Power supply davpond Buy & Sell 2 12-06-2019 08:06 AM
Where can i buy a Power Supply for my D-Command ? francois ICON & C|24 21 02-28-2019 05:28 PM
Command 8 Power Supply question MarkH ProControl, Control|24, Command|8 6 09-20-2017 05:11 PM
Command|8 Power Supply? stuseattle ProControl, Control|24, Command|8 5 05-03-2012 04:33 AM
Command 8 Power Supply infernojs ProControl, Control|24, Command|8 3 10-03-2005 12:59 AM
