Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 12-31-2012, 04:41 AM
luckydjacks luckydjacks is offline
Default "Tuner" and internal "DSP" doesn't work on Mbox 3 Pro
At the beginning of december I bought a Mbox pro (3G) with Protools 9.
Before installing Protools 9 and upgrade 10, i downloaded and installed Mbox Pro last driver (as AVID told it) => 1.0.19 with firmware 1.0.3.
My Protools 10 works well.
The Mbox Pro control panel shows internal dsp (rev, delay....) and tuner window.
Here is my first problem:
1)I plug my guitar into my Mbox pro ->input 1 => input and master signals are ok.
2)On input 1 -> hardware input FX send + software return FX sends + FX returns + effect duration, feedback and volume -> all knobs turned fully clockwise.
=> no effect sounds out, no signal in FX returns bargraph.
Here is my second problem:
3) When i open the "tuner" window => no signal , nothing happens.
Actually, i don't know if the problem comes from the new driver or my Mbox Pro hardware.
Could you help me to fix this malfunction ?
Thanks
Friendly.
Mbox Pro (3G) with driver 1.0.19 Firmware 1.0.3 + Protools 10.3.2 upgrade from PT9, ASUS Republic of Gamers G51J + Intel Quad Core i7 Q720 1,60 Ghz + RAM 4,00 Go + Windows7 64 Bit SP1.
Old 05-13-2013, 03:26 AM
Dexxy's Avatar
Dexxy Dexxy is offline
Default Re: "Tuner" and internal "DSP" doesn't work on Mbox Pro (3G)
Did anyone solve this problem?
Old 05-13-2013, 05:38 AM
Pinball Wizard Pinball Wizard is offline
Interesting. I don't usually use those features but I checked them and found that mine has the same problems. I'll work on it & post back if I discover anything.
Main Workstation: Pro Tools 2023.12.1, Windows 11, HP Z4 Xeon 8 core W2145, 64 GB DDR4, Omni, Artist Mix, Sync X, Eleven R(2 of them), UAD 2 PCIe card
Old 05-13-2013, 06:34 AM
guatamas guatamas is offline
I have similar issues with mine, when I bought the mb3p the internal tuner and DSP worked just fine, but since the firmware update before 1.0.3 caused this to stop working. This may be a driver/firmware issue. Hopefully someone can chime in with some details
Old 05-13-2013, 12:54 PM
Dexxy's Avatar
And I worked until I switched to v.1.0.19 / 1.0.3. Since then, we do not work .. I tried to go back to an earlier version at but not to downgrade the firmware.
Old 05-14-2013, 02:06 AM
Slidecode Slidecode is offline
I have the exact same problem here! I purchased an Mbox 3 Pro on Ebay and it came with the latest firmware. DSP Fx and Tuner not working! Has anybody contacted Avid about this?
Old 05-14-2013, 03:42 AM
Dexxy's Avatar
I have not contacted Avid. I did not have time. If someone does not contact anytime soon I'll do it.
Sent from my GT-N7100 using Tapatalk 2
Old 05-14-2013, 08:44 AM
I note that the tuner does not work 'stand-alone' ... it used to work that way just fine. That indicates that it is not a driver issue as no computer is involved. I am guessing that this is a problem created by the firmware update.
Old 05-14-2013, 08:58 AM
CHRIS AIKEN CHRIS AIKEN is offline
Default Mbox 3 Pro DSP FX Broken?
I have an an mbox 3 and I'm trying to get the onboard dsp effects working in my headphones but it seems like there's a problem. I've read up on it VERY carefully and as far as I can tell it should be working but it's not.
I've read a few other posts where people seem to have the same problem. Is this a known issue with the mbox?
Thanks,
Chris
Old 05-14-2013, 09:28 AM
Dexxy's Avatar
Default Re: Mbox 3 DSP FX Broken?
No one answers and there are many people who have this problem after the firmware update ...?
http://duc.avid.com/showthread.php?t=332691
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
3tuner" and internal "DSP" doesn't work on Mbox Pro (3G) luckydjacks Windows 0 12-31-2012 04:40 AM
Toggle Track view ("Opt"+"-") doesn't work LukeFromBerlin macOS 3 04-01-2012 04:43 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
