Old 03-31-2012, 04:28 PM
LukeFromBerlin LukeFromBerlin is offline
Default Toggle Track view ("Opt"+"-") doesn't work
I am still on PT8, but I hope this is the right forum for my problem...
PT Manual (and the DUC) says pressing "Option" and "-" toggles Track view between waveform and volume view (for all tracks)
Somehow this does not work for me, although I WISH I could use this function. I tried everything for hours.
When I press "-" by itself ....the activated region nudges.
When I press "Option" and "-" ... I get this bizarre error message:
"No Automation could be written because automation recording/playback is disabled for each of the individual controls and/or automation recording is disabled in the automation enable window"
I dont WANT to record any automation, I want to toggle the track view
The Shortcuts PDF says this works on "QWERTY" Keyboards only. I have a german keyboard, so it's "QWERTZ" (Y and Z positions are exchanged) ...but that can't be the reason, can it ?
Tried all variations of "Command" and "-", "Option" and "Shift -" etc etc. No chance.
Any clues or thoughts ?
THANX !!
Soft: ProTools 8.1
OS-X 10.6.8
Hard: ProTools HD 3, PCI-e core & accel, 96 I/O, 192 digital I/O, HD MADI / Sync I/O (not sync HD)
Quad-Core Mac, Intel
Old 03-31-2012, 10:36 PM
PD-John PD-John is offline
Default Re: Toggle Track view ("Opt"+"-") doesn't work
Are you pressing the right key? It's the one between "0" and "=".
Old 04-01-2012, 12:31 AM
I have 4 Keyboards flying around in the studio, all with an extra numeric keypad. On all of them the "-" is either on the "main" keyboard at the bottom, between "." and the right hand "shift" key... plus another "-" is located, as a part of the numeric keypad, to the right of the "9" (below "*" and above "+"). Both don't work.
Judging by the keyboard stickers supplied by protools, the key between "." and the shift key (also used for "_" <underscore>, using shift) should be right....
Does someone perhaps know about a little tool to make the "ASCII" codes for keyboards visible ? Then perhaps somebody (on whose keyboard the toggle works) could tell me the ASCII-code for the right key combination (Option-Minus) and then I could experiment with my (strange ?) keyboards how to get this ASCII...perhaps using a different key-combination.... ?
Or perhaps a different solution ?
PS: I am not in zoom toggle mode without knowing, I checked that.
Soft: ProTools 8.1
OS-X 10.6.8
Old 04-01-2012, 04:43 AM
************ SOLVED ***************
Thanks to PD Johns post I came up with the idea to check the apple online store for US-AMERICAN Keyboards (!) and look closely at them. And -he is right - on THESE keyboards the "-" is located between "0" and "=".
What do the german keyboards have there ? Something we call "sharp S" (ß)
So when I press "Option-Sharp-S" it WORKS
Hope this is helpful for all users with Keyboards different from US ... look what YOU have next to the "0" ....
Cheers from a Happy Bunny
Soft: ProTools 8.1
OS-X 10.6.8
"Tuner" and internal "DSP" doesn't work on Mbox 3 Pro luckydjacks FireWire & USB Audio Interfaces (Win) 129 06-20-2014 03:25 AM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
