  #21
Old 10-10-2018, 12:51 PM
zerodistraction zerodistraction is offline
Default Re: Video Card - Mac Pro High Sierra & Native
I recommend sticking to the list of compatible Metal capable GPUs in Apple's latest support article.
I recently replace my AMD 5770 in my Mac Pro with a Sapphire RX 580. It worked perfectly without any drivers in High Sierra.
Note that before upgrading, you will need to get an additional PCIE power cable as these GPUs require two of them. Also, if you're running an older Apple Cinema display, you'll need a mini Display Port to regular Display Port adapter.
https://support.apple.com/en-us/HT208898
  #22
Old 10-17-2018, 08:11 PM
685 685 is offline
I may try the MSI RX-560 to replace my HD5770
  #23
Old 10-21-2018, 05:16 AM
Peter Duemmler Peter Duemmler is offline
I did exactly that. Works great.
http://www.merlinsound.de
  #24
Old 10-21-2018, 07:22 PM
685 685 is offline
Cool deal. I only get CPU(-9093) spikes when I open a Waves plugin to make changes. No spikes/errors if the plugin windows is closed. (64 buffer)
  #25
Old 10-26-2018, 10:23 AM
SDDP SDDP is offline
This site should help everyone one what is compatible with Apples most successful Mac Pro:
https://everymac.com/systems/apple/m...splayport.html
-Mac Pro 7,1 16core 3.2GHz 96GB
-OSX 12.7.2
-PTHDN 2023.12 Ultimate
-HD Omni
-BM Intensity Pro
-Waves Mercury+SSL4000 Collection+Abbey Roads
-iZotope RX10 Advanced
-iZotope Post Production Suite 6
-iZotope Music Production Suite 5
-HALO UP/DOWN MIX
-ANYMIX
-Delonghi Perfecta ESAM 5600.S
  #26
Old 10-26-2018, 11:46 AM
MichaelK MichaelK is offline
Originally Posted by Siegfried Meier View Post
Hey guys,
Would love opinions on what card you guys are recommending with High Sierra and PT Ultimate 2018.4 Native. The stock card in our Mac Pro 5,1 2012 is no longer cutting it.
I've got the Sapphire HD 7950 in mind that OWC sells - it has 3072 MB of VRAM.
Would love to hear some thoughts!
Thanks,
Sig
I also have a Mac Pro 5,1. My ATI Radeon HD 5770 went to heaven a week ago and I replaced it with the Sapphire HD 7950 from OWC. It's working well except the display "blinks" once in a while when running certain programs, including PT. It also blinks when streaming videos on Firefox but not on Chrome, but that's possibly because I deleted Flash player.
That said, it's blinking much less often now than it did at first.
-- Michael
PT Ultimate Native 2021.10
Mac Pro 7,1 16-core, 288G RAM
OS 11.6.1 Big Sur
  #27
Old 10-26-2018, 05:21 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Not getting blinks here.
Double check (Move) the Mac PC switch possibly.
I use with three (1080-4K-1080) (DVI=DVI, mdp to dp, mdp active to DVI)
MacOs 10.14 seemed to better it's performance.
  #28
Old 10-27-2018, 01:39 PM
685 685 is offline
Installed the MSI RX560 Aero 4g.
Works well and improved my Protools cpu spikes/errors that I was having with plugins GUIs at 64buffer.
On startup, the apple boot screen only displays for about 2 sec then it goes to the login screen. Other than that, everything works. OS10.13.6
  #29
Old 11-25-2018, 04:44 AM
the.engineer the.engineer is offline
Did you get this sorted?
I’ve also used multiple computers to test this. With no edits, things run smoothly...the second I use Beat Detective and have lots of edits over a drum track, totally sluggish feel.
I am having the same issues and it's driving me insane. Have just bought a 6-core processor to put in the old 5,1 to try and resolve this issue. Also have my eyes on Sapphire HD 7950.
I can't handle beat detective being this unresponsive. See signature for system specs.
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #30
Old 12-02-2018, 02:03 PM
Having upgraded the Mac Pro 5,1 CPU from Quad-Core 2.4GHz to Six-Core 3.46GHz and the graphics card from from the Radeon 5770 to an AMD Radeon R9 280X with 3GB or VRAM, the difference is marked. I have attached a screenshot of a big session and you'll see the load on CPU and HDX. This was able to play on loop without any errors.
The pain with upgrading the graphics card is of course powering it alongside the HDX card, however if you're handy with a soldering iron you can splice the HDX power connector into the graphics card power cable so the graphics card is still getting it's juice from both PCI Aux Power Sockets. I've heard the HDX only needs power for the fan so is not a huge draw.
I have more tests to do so will report back.
James Welch
MAC PRO High Sierra & PTHD 2018 can't recognized PCIe Native card Sutee Sangsareechon Pro Tools 2018 1 05-11-2019 04:48 PM
S6L AVB with OS X High Sierra brinnbacka VENUE Live Sound Systems 3 10-20-2018 12:52 AM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
High Sample rates with Native HD card Media Man Windows 6 02-27-2017 11:48 AM
HD Native card physically generates high pitch whine or squeal mlange Pro Tools HDX & HD Native Systems (Win) 6 03-15-2012 02:59 AM
