Old 05-31-2014, 04:57 PM
janitorking janitorking is offline
Default updating from pro tools 8 to 8.0.5
hello. i'm new here and to pro tools. i'm running pro tools 8 on my mac book pro OS X. one of the free digidesign plug-ins that comes with 8 is called Structure Free. every time i tried using this plug-in, the interface came up all yellow and "glitchy", for lack of a better way of describing it. i read a number of forums and found that i was not the only one with this problem. the advice given was to install the pro tools 8 LE updater which i did. i installed update 8.0.5. now when i try to open pro tools i get a message saying "unable to locate digidesign hardware, make sure all cables are plugged." all of my cables are plugged in properly and this is not a problem i was having before i installed the update.
please help!!
Old 05-31-2014, 05:40 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: updating from pro tools 8 to 8.0.5
Try re-installing the latest drivers for your interface.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 05-31-2014, 05:52 PM
can you kind of walk me through that process? i'm really new to pro tools and computers in general.
Old 05-31-2014, 05:56 PM
zedhed's Avatar
What Audio Interface are you using?
HD 96I/O
Old 05-31-2014, 06:07 PM
Mbox 1
Old 05-31-2014, 07:04 PM
zedhed's Avatar
I'm not a Mac guy so not sure about the process of installing drivers on Mac computer. But installing the Mbox drivers will be no different than installing any other drivers.
Having said that; the Mbox 1 is pretty outdated so I'm wondering if the Pro Tools software update has rendered the Mbox drivers useless. I don't know if this is the case but re-installing the latest available ones won't do any harm.
HD 96I/O
Old 05-31-2014, 07:32 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Originally Posted by janitorking View Post
Mbox 1
The original Mbox (upright model) will not work with Pro Tools beyond Pro Tools LE v8.0.1. The Mbox drivers are automatically installed when you install Pro Tool LE 8.0 or 8.0.1.
Click on the Compatibility links at the top of the forum for more info operating systems and pro tools version support.
Deeper links will get you to these pages from there:
The yellowish look of Structure Free (automatically installed with Pro Tools LE) may be an incompatibility with that plug-in and your operating system, but I don't know what exact version number of OS X you are using. Pro Tools LE 8.0.1 was not supported on Snow Leopard (Mac OS X 10.6).
Bruce Paine
System Details
Old 05-31-2014, 07:53 PM
yikes. this might seem like a stupid question but now that i've updated to 8.0.5, how do i get back to just 8? this is a lot more headache than structure free is worth at this point.
Old 05-31-2014, 08:10 PM
Admin Emeritus
I don't have a copy of the installer disk or download installer for 8.05 handy, but if it has an "Uninstall Pro Tools" application in your download, run that and do a "clean uninstall".
Then reinstall Pro Tools LE 8.0, then v8.0.1, then v8.0.1cs2.
Bruce Paine
System Details
Can someone please help me with updating Pro Tools 10 sb_stefan Pro Tools 10 14 09-09-2013 09:08 PM
Need help updating Pro Tools please bdavidson10 General Discussion 5 01-20-2011 08:31 PM
Error while updating from Pro Tools 7.1 to 7.1.1 bigfootjim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-20-2007 12:50 PM
Updating Pro Tools 6.7 to 6.9 HD dvillage Pro Tools TDM Systems (Mac) 3 07-01-2005 02:52 PM
Updating to Pro Tools LE 5.1.1 T-Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-10-2001 09:54 AM
