Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 07-14-2019, 07:32 AM
Sardi Sardi is offline
Default Re: Aux channels - still hearing the input tracks?
The better way would be to route the output of the channel to the buss, rather than via sends.
But if there’s a reason you need to do it this way, make the sends pre fader and mute the tracks.
Old 07-14-2019, 07:37 AM
briaboy briaboy is offline
Mmm, so one person says use sends, and you're saying that routing the output is better? ok....I'll try both and see what works! Thanks!
Old 07-14-2019, 07:42 AM
Default Aux channels - still hearing the input tracks?
Who said to use sends?
Regardless, the choice is yours. But normally, you’d route the outputs of your channels to a buss for a global effect such as compression or to control the whole submix level via a single fader. You’d use sends to... well send the signal to a shared time based effect such as reverb or delay.
Also, doing it the way I suggested would fix the problem you’re having.
Old 07-14-2019, 08:00 AM
Do you mean like this? Thanks.
Old 07-14-2019, 09:12 AM
BScout BScout is offline
Screenshot makes it clear what you’ve done wrong because at no point did you mention the sends.
You’ve double bussed your audio tracks. Remove or disable sends and set the drum audio channels out to your bus 3-4 instead of 23-24. If you want to be able to hit solo on the aux, solo safe each of those drum audio channels so they don’t get muted
Last screenshot is right. (But you need to solo safe still if you plan to use solo on the aux)
  #16
Old 07-14-2019, 09:17 AM
If you choose to use pre-fader sends (wrong choice in my opinion), you also need to set levels from the sends because the main fader levels in those channels will then be ignored.
  #17
Old 07-14-2019, 09:52 AM
Perfect, thanks for your patience and apologies for the lack of clarity!
Hearing all tracks in scrub and shuttle clgood Artist Series 3 12-08-2014 07:08 PM
Hearing recorded tracks while recording Durstlaw FireWire & USB Audio Interfaces (Win) 6 03-19-2014 11:44 AM
MIDI Input from keyboard, lag before hearing sound danjfoley Windows 3 01-13-2014 01:55 PM
hearing midi tracks through mbox pmclellan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-18-2005 08:44 PM
Problem with hearing certain tracks..... connelldestructo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-09-2005 07:16 PM
