  #31
Old 09-24-2015, 07:11 PM
milosziv milosziv is offline
Default Re: Pro Tools 11 on mac not showing waveforms
I agree - this should not be happening on your final release of an upgrade version Avid. You can't leave a version behind full of bugs - and then ask us to pay you for a fix by upgrading.
Also please deal with your Yosemite problems with the Core driver conflicting with other drivers like Maschine!!
  #32
Old 10-29-2015, 06:14 PM
joseph_g joseph_g is offline
Myproblem is with Pro tools 12. In normal mode I am not showing wave forms during recording. They are there after recording and playback. Waveforms is set, not block or something else. I know with some of the other options,like Quick Punch, the wave forms do not show while recording.
  #33
Old 01-11-2016, 04:54 PM
TLarkin TLarkin is offline
I have the same problem of the waveform not showing up in 11. When I open the session in 10 it draws the waveforms just fine, then I re-open in 11 and they are there. Quite a workaround and waste of time, but the only way I can get it to work.
  #34
Old 07-05-2016, 01:30 AM
GTBannah GTBannah is offline
So, I see the problem still exists! I guess there's no upgrading for me, then. SMH
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
  #35
Old 07-10-2016, 11:56 AM
Well. I seem to have found a work-around, as far as importing video goes.
I extracted the audio from the video in another programme, imported the video without the audio, then imported the audio separately. Put them both at session start, and off you go.
I hope this helps.
Derrkins
GuyBarTola
  #36
Old 08-05-2016, 11:08 AM
MfMcAdam MfMcAdam is offline
I have this problem occasionally and found a workaround. Select the region(s) in question... then look under VIEW> WAVEFORMS> and toggle between "Peak" and "Power" a couple of times. Usually works for me. You may have to increase the size of the waveforms, too.
  #37
Old 09-12-2017, 10:53 PM
Tybone Tybone is offline
Thanks for the tips. Closing and reopening PT 11.3.1 for mac did the trick. Odd little bug though.
Waveforms not showing when recording Dizzi45Z Pro Tools 10 3 10-29-2015 11:10 PM
PT 8 not showing waveforms crypt0r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 11-08-2011 07:31 PM
Pro Tools 9 Waveforms firebass305 Pro Tools 9 10 11-19-2010 11:09 AM
Pro Tools not showing waveforms (in centre) TheBeats Pro Tools M-Powered (Win) 1 12-12-2009 09:22 PM
No Waveforms showing when I use Rewire essplode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-17-2008 09:35 AM
