Need some help - I/O not showing up right.
I've upgraded to PT10.
I did a safe uninstall. On my laptop I'm using my M2 Micro. It worked fine on Pt9. I updated to the latest Mini driver. When I hit "n", all I get is MBox2, not mini. I have used my Mbox2 on my laptop for field recording but there was never an issue going back to the mini on PT9. When I goto Hardware, it shows the micro. When in I/O it shows the Mbox2. In Audio/Midi setup it shows the micro. So I don't know why PT10 isn't seeing the micro in the setup. Any suggestions? Anyway to uninstall the older drivers? Thanks |
Re: Need some help - I/O not showing up right.
Great!
Great! I presume you mean Mbox 2 Micro? Quote:
Same here. I am going to suggest that there isn't a problem. Maybe the labeling could be more consistent. Have you actually tried using the Mbox 2 Mini? Did you just see these labeling discrepancies and think that something is wrong?
Well the fact there is no audio points to something not working.
I installed PT10 on my other mac, and had no issues. Seems only to be with the micro |
Can you access both Macs at the same time for comparison? There's only one driver install for all Mbox 2 interfaces, so it seems odd that the driver would be the problem if one of your interfaces works and the other does not.
Clean install seemed to do the trick.
Thanks |
003 not showing up | Grant26 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-14-2012 03:45 PM |
SD2.0 not showing in PT9 | Kpu1127 | The Drum Room | 4 | 04-18-2011 06:57 AM |
003 Not showing up in AMS w/ PT9? | soundboy35 | macOS | 3 | 01-08-2011 12:44 AM |
What Should an 888/24 Be Showing? | bradjacob | Pro Tools TDM Systems (Mac) | 1 | 10-22-2008 09:00 PM |
3rd 192 not showing up | deerock | Pro Tools TDM Systems (Mac) | 6 | 03-24-2002 10:27 PM |
