AAX (Dsp) & AAX Native (Daw Cpu) ?
AAX (Dsp) & AAX Native (Daw Cpu) ???
but manufacturers say only : AAX thanks for any info about |
Re: AAX (Dsp) & AAX Native (Daw Cpu) ?
Yes.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Usually a developer will say 'aax dsp' if a plugin supports that. Otherwise when you see 'aax' only take it to mean aax native.
What Jack said and also take it to be AAX 64 bit as most devs do 64 bit and have dropped 32 bit aax plugin support.
Obviously AAX32 only affects PT10 which is already old enough; but yes, if you are using PT10 then you should be extra careful and ask the developer directly if their plugin works in PT10 or not.
Then : AAX do not mean that if you have HDX card the plug in work as the old TDM with instance on the dap card (low digital word data compression) , and if Native (no HDX card with dsp) the same AAX plug in is processed by the Cpu D.a.w. computer as for the old RTAS , and Vst , AU ….. (with more digital word data compression) ? but why a 32 bit on today pro tools with 64 bit processing ? if used with PPC Cpu , Windows XP ,Cubase & co. ? more thanks for any info about ! |
AAX dsp means if you have an HDX card it gets processed there on the dsp on the card. AAX means it gets processed by the computer's cpu. |
Yes and there is no difference in sound, compared to RTAS/TDM era when one was 32float and another was 48fixed
placed inside the HDX card dsp chip and on the D.a.w. cpu , sound identical ? (64 bit) still cannot understand why the plug ins manufacturers do not specify : AAX-Dsp & AAX-Native |
FS: McDSP Analog Channel Native V5, 6020 Ultimate EQ Native V5 | soundroad | Buy & Sell | 31 | 03-21-2016 06:03 AM |
Does HD native or native native disable plugins when monitoring inputs? | BasketCase | Pro Tools HDX & HD Native Systems (Mac) | 7 | 05-20-2013 08:48 AM |
FLUX Elixier V3 AAX Native & DSP + Freeware Bittersweet V3 AAX Native & DSP released | psmworld | AAX Plug-ins | 18 | 01-31-2013 04:16 PM |
SSL4000 native/ Renmaxx native/ DUY everpack native!!! | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-22-2007 07:58 AM |
