Old 01-01-2017, 07:07 PM
moshuajusic moshuajusic is offline
Default Re: Could use a shortcut for soloing the track while in a playlist lane
http://protools.ideascale.com/a/dtd/...or/258751-3779
I added b1daly's idea, with a small tweak: I still think shift-S would be useful for soloing/un-soloing a playlist lane, so you can compare the take to the main playlist clip.
Old 01-13-2017, 04:58 AM
Apparently, someone flagged my post after I added b1daly's suggestion because that part had been requested before. So I had to remove it. Sorry, b1.
So ladies & gentlemen, please go vote on BOTH ideas:
http://protools.ideascale.com/a/dtd/...ne/258751-3779
http://protools.ideascale.com/a/dtd/...ck/109340-3779
Really surprised the 2nd one didn't get more traction originally. Seems like such an obvious idea, I know I've seen it mentioned before, and it would tremendously speed up workflow.
Old 01-23-2017, 11:32 PM
propower propower is offline
Originally Posted by b1daly View Post
on a related subject, I would really like a mode where moving up and down the playlists would have the solo follow the selection. So you wouldn't have to move the selection, then set the solo to follow (shift S).
If this was the case, shift S could be bound to solo just the track as OP is looking for.
Anyone else wish for this?
Another +1 on this. Such a necessary thing for comping
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 11-07-2019, 06:20 PM
Bump and +1
I was just going thru playlists and realized how sad it is that we don't have this yet. Even worse, soloing a playlist with the mouse predictably and correctly leaves the track solo'd, while soloing a playlist with shift-S inexplicably unsolos the track.
I'm also disappointed--correct me if I'm wrong--that there's no shortcut for cycling thru playlists. You have to make a selection first, and then cycle. That's cool and useful, but it'd be nice to skip the selection part in some cases.
Grouped Track Playlist solo shortcut??? Epik Productions Pro Tools TDM Systems (Mac) 2 07-25-2010 09:51 AM
LE 8.0.3cs2 not saving playlist lane filter settings?!! cabbagerock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-06-2010 04:11 PM
New Playlist shortcut? Mix Master Factories 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-03-2010 03:32 AM
New playlist shortcut? jdutaillis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-20-2009 10:22 PM
Shortcut for "New playlist" FrauMitBart Pro Tools TDM Systems (Mac) 1 04-01-2005 12:57 AM
