Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-07-2014, 09:56 PM
malmalibu malmalibu is offline
Default S/pdif out of M-Audio Fast Track Ultra 8R into S/pdif in Focusrite VRM Box
Am trying to run S/pdif out of M-Audio Fast Track Ultra 8R into S/pdif in Focusrite VRM Box so that I can monitor mix on M-Audio FTU using KRK Rokit 10-3 Speakers and also monitor mix on Focusrite VRM Box using studio headphones. Currently I have to change Playback Engine in Pro Tools 10 Setup to switch between the two monitoring systems. I set up hardware as per Focusrite VRM Box web instructions and there is no link of s/pdif signal ? I have visible signal from M-Audio FTU S/pdif software control panel but no linked signal on the Focusrite VRM software control panel. Appreciate any replies that can assist me with this as i have not found a solution on Avid 'M-Audio' & Focusrite websites or youtube Cheers
Norman A Hamley www.malibugroove.com & www.timelessrocknroll.com
Old 11-09-2014, 05:29 PM
Default Re: S/pdif out of M-Audio Fast Track Ultra 8R into S/pdif in Focusrite VRM Box
Found fix - Focusrite VRM will not work in USB3 and using USB2 port on Laptop will allow me to get it's S/PDIF 'in' to link to M-Audio FTU 8R S/PDIF 'out'
Old 11-14-2014, 05:21 PM
Christian.Focusrite's Avatar
Christian.Focusrite Christian.Focusrite is offline
Focusrite
For anyone interested here's the set up for the vrm box with a audio interface:
http://us.focusrite.com/answerbase/h...udio-interface
Old 11-17-2014, 09:24 AM
Looking for any Member that can advise me of any youtube or web sites that help understand & explain the use of each room/speaker setting in Focusrite VRM Box. This would be valuable info when doing mixing in Pro Tools 10 DAW
Last edited by malmalibu; 11-19-2014 at 03:49 AM. Reason: Clarify & correction of reply
Old 11-21-2014, 02:26 PM
Focusrite
Here's a link on mixing with the vrm:
http://www.youtube.com/watch?v=sSXImtMhIWY
M-Audio Fast Track Ultra Help! Szenasi FireWire & USB Audio Interfaces (Win) 2 05-26-2013 11:55 AM
Fast Track C600 - Not able to use S/PDIF as 5.1 output nix Pro Tools M-Powered (Win) 0 02-07-2013 08:02 AM
5.1 with M-Audio Fast Track Ultra 8R Elby Post - Surround - Video 3 05-25-2012 08:43 AM
AMIII S/PDIF in from Second Audio Card S/PDIF Out? bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-04-2005 10:30 AM
