Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 11-06-2018, 04:20 PM
unkJE's Avatar
unkJE unkJE is offline
Default Steven Slate Drums 5 (SSD5 and SSD5 FREE) Now Available!
http://stevenslatedrums.com/ssd5/
SSD5 Overview
– All New User Interface Built from the Ground Up
– New Master Volume Engine Control
– New SSD5 Physically Modeled Drum Playback Algorithm
– Deluxe 2 Drum Library Adds 50 New Instruments
– 77 Snares, 84 Kicks, 58 Toms
– 11 Hi-Hats, 14 Crashes, 6 Rides, 4 Splashes, 3 Chinas
– 9 Percussion Instruments (1 Clap, 1 Tambourine, 1 Cowbell)
– 4 Sound Effect Instruments
– Analog Processed and Unprocessed Samples
– Famous “Artist Modeled” Kits
– Drumkit or Pad Cells View Allows Up To 32 Drum Instruments
– Completely Reworked Routing/Mapping System
– macOS Support in AAX/VST/AU Formats
– Windows Support in AAX/VST Formats
Introducing Steven Slate Drums 5 (SSD5) Now Available!
https://youtu.be/a2XeVpjg-s8
SSD5 UPGRADES
SSD4 Platinum and SSD4 EX Users: Get Discounted Upgrades to SSD5 until November 30th
http://www.stevenslatedrums.com/ssd5/#SSD5UPGRADES
SYSTEM REQUIREMENTS
macOS Minimum Requirements
SYSTEM SPECIFICATIONS
1 GHz Intel Dual Core Processor or AMD Equivalent
4 GB of RAM
macOS 10.8 or later
AAX, VST, AU supporting DAW
SCREEN RESOLUTION
SSD5 requires a screen resolution of 1024 x 768 or higher
LICENSING
SSD5 licensing supports iLok Dongle or Machine ID.
Windows Minimum Requirements
4 GB of RAM
Windows 7 or later
SCREEN RESOLUTION
LICENSING
EASY EDITING
SSD5 makes editing your kits a breeze. Select individual drums, customize the mics and routing, choose your MIDI maps, customize your velocity and dynamic curves for each drums, and build your custom tone exactly as you want it.
MIX IT
SSD5’s mixer allows you to get the perfect mix of your drums, with easy access to ambient room mics and close mics. It allows you to easily route your drums discretely to your DAW so you can use your favorite plugins to get the ultimate drum tone. We also added a new master volume control to the entire plugin.
MAP IT
Customize your MIDI Map with SSD5’s completely reworked MIDI MAP converter. Everything in a kit preset is easily mappable and re-mappable plus you can quickly load mapping presets.
SSD5 FREE
Experience a taste of SSD5 with full functionality and one incredible Deluxe 2 Kit for FREE. Not an expiring demo!
Last edited by unkJE; 11-06-2018 at 04:55 PM. Reason: SSD5 FREE included in heading (thanks Andrei!)
Old 11-06-2018, 04:27 PM
amagras amagras is offline
Default Re: Steven Slate Drums 5 (SSD5) Now Available!
Free sample kit? I'm finally having some SSD! Thanks unkje
amagrasmusic.com
Old 01-14-2019, 03:04 PM
b mcgibney b mcgibney is offline
Default Re: Steven Slate Drums 5 (SSD5 and SSD5 FREE) Now Available!
I've gone through the install process but when I try to load up the two sample packs they are greyed out. I can open the drums in a PT session. but without the samples nothing is going to happen. Anyone else have this problem?
FWIW I'm on a 5,1 cheesegrater running the latest PT 2018
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers
Old 01-14-2019, 04:47 PM
unkJE's Avatar
Hi
Within Install Manager, did you select:
(1) Path to SlatePack files
(2) Destination for SSD5Library folder (internal or external HD)
as shown here:
How To Install SSD5 Free on macOS
https://www.youtube.com/watch?v=rbr0fsC8xWk
(above video - @ approx 1:10) - in SSD5 Free Settings: select Base Directory (location of SSD5Library)
Old 03-06-2020, 01:16 PM
CLaws CLaws is offline
Hi, all. How much HDD space does SSD5 require? I can't find this info anywhere. Thanks!
Macbook Pro Mid 2015
Quadcore i7 2.2Ghz
256SSD
16gb RAM
Sierra
Clarett 4Pre
Protools 12.7.1
WD 1TB USB3 External Drive
Lacie 1TB Thunderbolt External Drive
Old 03-20-2020, 10:50 AM
Things are a bit convoluted to me as well. My first install only gave me 1 kick sample and 1 snare sample I went back to the drawing board:
https://stevenslatedrums.com/videos/
Select your OS(I'm on Windows) and watch the video. I re-ran the installer and things looked the same. A bit of clicking around, I hit the Kits button(to the right of LIBRARY) and found a single(but complete) category called "01 Rock Kits" and under the KIT PRESET column, I see 3 kits listed and they sound essentially the same, but with differing amounts of ambience. In any case, the library shows as around 2GB on my samples drive. I'm going to experiment and dig some more and will report back if I make any important discovery
Old 03-20-2020, 04:11 PM
Thanks........................,Dave.
Quadcore i7 2.2Ghz
256SSD
16gb RAM
Sierra
Clarett 4Pre
Protools 12.7.1
Old 03-20-2020, 05:25 PM
AlexLakis AlexLakis is offline
FWIW, I've had SSD since the CD-R days, and my samples folder has always been a sh*t show. Maybe I'm doing something wrong, but I have to swim for samples that will load. Just my experience.
Old 03-20-2020, 05:40 PM
FWIW I never could record audio to Windows. I went to Mac and have had great success... at least, it works. So that MAY be a consideration.
Quadcore i7 2.2Ghz
256SSD
16gb RAM
Sierra
Clarett 4Pre
Protools 12.7.1
Old 03-20-2020, 08:58 PM
unkJE's Avatar
The full SSD5 needs almost 18GB – allow for around 20GB if you add Trigger Instruments and one Expansion.
Free SSD5.5 Update for SSD5 owners:
http://duc.avid.com/showpost.php?p=2557441&postcount=64
FS: Slate Digital, Steven Slate Drums, Eventide, Softube sadateffendy Buy & Sell 7 08-11-2016 05:14 PM
Slate Digital and Steven Slate Drums AAX DHL AAX Plug-ins 6 04-22-2013 12:50 PM
steven slate drums 4 bchelune Pro Tools 9 4 03-07-2013 06:03 PM
PT8 LE and Steven Slate Drums outlaw69uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-30-2010 08:00 AM
Steven Slate Drums....$20 pguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-27-2010 12:40 PM
