Old 03-27-2009, 12:53 PM
alextouch alextouch is offline
Default ProTools 8 LE question
Hi all,
just have a question about the CPU (Rtas) usage.. when going on Setup>Playback Engine and choosing 4 Processors instead 2 Processors, on the "System Usage" window the CPU Rtas usage is doubling... is that normal and why? i've a Intel Core2 QuadCore Q9550 @2,83GHz built on Asus P5QL PRO and 4 GB ram Corsair @1066MHz (2x2Gb)
Thanks in advance
Old 03-27-2009, 01:27 PM
RiF RiF is offline
Default Re: ProTools 8 LE question
OK, just to summarize: You have a Quadcore 2,83 GHz CPU accompanied by 4 GBs of 1066 MHz RAM. So why do you care about the RTAS usage meter...?
Old 03-27-2009, 02:58 PM
TOM@METRO's Avatar
I have a similar system, on the big session I currently have up;
2 processors= 60%
3 processors= 49%
4 processors= 39%
I typically run 3.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-27-2009, 05:02 PM
i currently set up the buffer on 128 for the tracking... another question... what kind of operating system do you use :)? Xp or Vista?
Old 03-27-2009, 07:54 PM
More XP users than Vista. Vista nets you less power at this point. Hopefully Win7 will make it better.
Old 03-28-2009, 01:34 AM
TOM@METRO's Avatar
XP
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 03-28-2009, 06:45 AM
shea shea is offline
2 processors= 60%
3 processors= 49%
4 processors= 39%
I typically run 3.
Hi Tom
Why would you not use 4 procs?
Nice studio by the way,is that a pair of ns 10's I see very hard to get now a days?
Ive sent you a recorded sample of a single via your site contact for your opinion which would be appreciated.
seamus
Old 03-28-2009, 10:47 AM
hmmm TOM@METRO, what kind of audio card are you using? and have you ever got problems with Protools 8 LE? i tried also Waves plugin on it and got crashes @start...
Old 03-28-2009, 03:06 PM
Driven01 Driven01 is offline
The high cpu usage is a know issue with PT 8. According to Digi Support, it has something to do with "blitting" (how the windows are drawn) that is causing the issue. Digi says they're working on a fix but it's "rather invasive" and is taking some time to correct and test. If, because you've got a quad core and plenty of ram, it's not affecting your productivity, wait for a fix and continue on. If it is affecting productivity (like it did me) go back to 7.4 until they have a solid fix for PT 8. It's already been close to 3 mos. since the issue was identified and a solid fix isn't in sight yet. Try a search in the DUC for high cpu usage. You'll come up with a lot of threads since PT 8 was released.
Old 04-01-2009, 04:04 AM
Oh thank you so much,my last question is this:
Is it a normal bug on protools le 8 to have got the cpu usage lower when i use 1 processor and higher when i use 4 processors?
talkin about 15% higher with 4 processors.
Anyone 's got this problem with digi002?
Protools HD2 question Mr.SCS Pro Tools TDM Systems (Mac) 7 08-25-2013 10:25 AM
protools 9 HD question...PLEASE HELP!!! bicasso macOS 4 03-20-2012 05:17 PM
Protools 8.03 Question... GordoBot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-10-2010 09:25 AM
PROTOOLS LE 5.3.1 QUESTION NewYorkSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-21-2003 06:28 PM
Protools Question! Lukas79 Tips & Tricks 21 07-23-2002 11:19 PM
